How would you love to modify your pickup?
By abenleulmi
The thermostat is a crucial component in your car's engine system, playing a vital role in regulating the engine temperature. Contrary to common beliefs, removing your car's thermostat can lead to severe consequences, affecting fuel efficiency and engine lifespan. In this article, we will explore the benefits of retaining the thermostat and explain why removing it should be avoided. link hidden, please login to view -
By WiperTech008
When Should You Replace Your Wiper Blades?
Wiper blades keep your windshield clear, but since they’re made of rubber, they wear out with time and need to be swapped out regularly. How long they last really depends on how often you use them, where you drive, and whether you take care of them. Watch for these signs that indicate it's time for new wipers:
Streaking or Noise
Notice streaks or that awful squeaking sound? Yep, it’s probably time for a new pair. For a temporary fix, clean the blades with vinegar or alcohol, but replace them as soon as possible.
Visible Damage
Check the rubber blades regularly for cracks, chips, or deformities. Any damage means it's time for new wipers.
Age Considerations
Standard wipers typically last 6-12 months
High-quality blades with proper care can last 2+ years
Frequent use or harsh conditions (sun exposure, dry wiping) may require replacement every 6 months
Just a heads-up—if your car sits in the sun a lot or you use your wipers all the time, it’s smart to check them more often.
By APF
Choosing between original and aftermarket car parts — and even used parts of either type — is all about squaring your priorities with your budget.
» SIGN UP: link hidden, please login to view
Original equipment manufacturer (OEM) parts match those that came with your car, and are of the same quality as its original parts. They’re also the most expensive. Aftermarket parts are cheaper, and made by other manufacturers — often several, giving you more options. Used parts may have a bit of wear and tear, but should be inspected or rebuilt to ensure they’ll work. These are the cheapest option. Choosing between aftermarket and OEM parts
Aftermarket parts come at varying price points and levels of quality, but because they are cheaper, insurance companies often prefer them. If you want OEM parts but are dealing with an insurer that wants the shop to use aftermarket parts, ask to pay the difference.
If you’d like to modify your ride by adding something like a backup camera or back-seat TV screen, you’ll probably be looking for aftermarket parts. Certain aftermarket upgrades could increase
Dealership repair shops will offer only OEM parts — they have no reason to offer a cheaper product from a competitor link hidden, please login to view may be able to offer you a choice between OEM and aftermarket parts Independent garages that specialize in your type of vehicle will likely have both, but with quicker access to OEM parts, including used OEM parts, which can really save you Auto body shops can offer both, but if your collision repair is part of an insurance claim, the insurer will likely prefer aftermarket parts to save money Depending on the job, the cost of OEM versus aftermarket parts varies. Whenever you’re given the choice, ask to see estimates for both so you can weigh your options.
By Nancy Bitter
