How To: Replace the Radiator Hoses on a 2006-2014 Ford F-150
O'Reilly Automotive Reportedly Bids $10 Billion+ for Genuine Parts' Napa Auto Parts Business
By APF,
- 1,059 views
- 32 views
- 54 views
- 48 views
- 48 views
If you've owned a Ford long enough, you've probably heard someone say, "It turned out to be the PCM." While the Powertrain Control Module (PCM) isn't the most common failure point, it can create symptoms that look like almost anything else.
Because the PCM controls critical engine and transmission functions, a fault can easily be mistaken for bad sensors, ignition issues, or even a failing transmission. That often leads to replacing parts that weren't actually the problem.
Common Symptoms of a Failing Ford PCM
Here are some of the symptoms I've seen discussed most often:
Check Engine Light that returns after repairs Engine cranks but won't start Random stalling while driving Rough idle or engine misfires Poor fuel economy Delayed or harsh transmission shifts Cooling fan running constantly Multiple communication (U-code) errors No communication with the scan tool The tricky part is that these symptoms can also be caused by wiring problems, low battery voltage, damaged grounds, or faulty sensors.
Don't Assume the PCM Is Bad
Before replacing the PCM, it's worth checking a few basics:
Battery voltage and charging system All PCM power and ground circuits Fuses and relays Wiring harness damage Corroded or loose connectors CAN Bus communication Water intrusion around the PCM I've seen situations where a damaged ground cable or corroded connector caused symptoms identical to a failed PCM.
Ford Models That Come Up Frequently
Certain Ford platforms seem to generate more PCM-related discussions than others, including:
Ford F-150 Ford Explorer Ford Escape Ford Expedition Ford Mustang Ford Ranger Ford Super Duty (F-250/F-350) Ford Fusion That doesn't necessarily mean the PCM is defective—it simply means these vehicles are commonly diagnosed when electrical or drivability issues appear.
When Replacement Becomes Necessary
If you've confirmed the PCM itself has failed, replacing it isn't always as simple as plugging in another module. Depending on the model year and vehicle, the replacement PCM may require:
VIN programming Security (PATS) programming Calibration updates Idle or transmission relearn procedures Installing an incorrect or unprogrammed module can prevent the vehicle from starting or lead to additional fault codes.
Modern Ford trucks and SUVs rely heavily on electronics, so accurate diagnosis is more important than ever. Taking the time to verify power, grounds, wiring, and communication before replacing expensive components can save both time and money.
Discussion
For those who own or work on Ford vehicles:
What Ford model gave you the most trouble? Have you ever had a PCM fail, or did the issue turn out to be something else? What symptoms led you to the final diagnosis? I'd be interested to hear everyone's experiences and see if there are any common patterns across different Ford models.
By OReilly Auto Parts
How to Replace an Engine Air Filter: 2004-2008 Ford F-150 | O’Reilly Auto Parts
How to Replace Windshield Wiper Blades: 2004-2008 Ford F-150 | O’Reilly Auto Parts
