How To: Replace Tail lights on a 2009 to 2014 Ford F-150
- 71 views
- 129 views
- 214 views
- 285 views
- 222 views
By chevyguy
I've got a 2014 Chevy Equinox with new pluigs, coils, fuel injectors, recent top-engine carbon clean, new AC Delco O2 sensors, and relitively new CAT. Getting a P219A-00 for Fuel trim cyliner balance. Any ideas where to start diagnosing? I saw this online as possible causes:
Leaking or contaminated fuel injectors Low fuel pressure or running out of fuel Leaking evaporative emission (EVAP) canister purge valve Exhaust or intake air system leaks Exhaust gas recirculation (EGR) system Positive crankcase ventilation (PCV) system is leaking or the valve is stuck open Ignition system Incorrectly seated engine oil dipstick, tube or oil fill cap Just curious if anyone has had this issue with a GMC of Chevy and succesfully diagnosed.
By WiperTech008
Streaking or Noise
Visible Damage
Age Considerations
By WiperTech008
By jacob_1994
I broke the steering knuckle on my truck and can not find the part anywhere, i need to know if there is another year that fits or if you know where i can get one or have part numbers. the truck is a 1999 ford ranger xlt 4x4 4L v6
