The future of mobility is electric, notes
, which predicts that in 2035, around 50% of the newly manufactured cars and light commercial vehicles worldwide will be fully electric and 30% hybrid. Another 20% of all newly manufactured passenger cars will have only an internal combustion engine in 2035.
The regional markets paint a nuanced picture of the powertrain mix, as Matthias Zink, CEO, Powertrain & Chassis, explained in his keynote address at the 2026 Vienna Motor Symposium: “Whereas here in Europe, we are gearing up for a ban on internal combustion engines more or less due to current legislation, we are seeing significant demand for hybrid vehicles in markets outside the EU far beyond 2035.”
2035 Powertrain Mix and Regional Markets
Above all, in North and South America and in Southeast Asia, hybrids are set to dominate new vehicle production within the next 10 years. In Japan, hybrids will account for as much as around 77% of production.
“In this context, our technology-neutral product strategy embracing all powertrain system options helps us to manage these mixed market developments and above all, address increasing customer demand for hybrid solutions,” says Zink.
Volume Production for Dedicated Hybrid Transmissions
The company said it sees potential in the efficiency and flexibility of hybrid powertrain technologies in close collaboration with vehicle manufacturers worldwide. This is why Schaeffler offers components, including complete systems, for diverse hybrid topologies—mild, full, and plug-in hybrids and vehicles with range extenders. These vehicles play a role in reducing CO2 emissions and achieving fleet targets when driven predominantly in electric mode.
Schaeffler started developing complete systems for the hybrid powertrain more than 10 years ago. A current example is the company’s MultiMode dedicated hybrid transmission, which goes into volume production this year worldwide at various European and Asian vehicle manufacturers. It is an integrated system with two electric machines, power electronics, and hydraulics for cooling and actuation of the clutch and parking lock. Schaeffler supplies the associated software and functions from a single source.
The total weight of the compact module is 125 kilograms and delivers up to 145 kilowatts of peak power. It is suitable for full and plug-in hybrids and offers three driving modes: electric, serial and parallel. In serial mode, this flexibility allows the internal combustion engine to operate consistently at optimum efficiency. Several presentations at the Vienna Motor Symposium addressed the dedicated hybrid transmission.
Zink explained the strategic rationale behind it: “We are convinced that hybrids offer consumers an easy introduction to electric mobility. If driven extensively in electric mode, these vehicles make an important contribution to the decarbonization of the mobility sector. Every gram of CO2 saved counts.”
Components for the Hybrid Powertrain
Internal combustion engines in hybrid powertrains also have to be efficient and meet future emission standards and noise requirements. Ideally, they should be designed so that the driver doesn’t detect any difference between electric and internal combustion engine driving mode. Schaeffler sees innovation potential in this requirement.
The company said it is developing damping solutions like the spoke damper, which eliminates torsional vibrations at the crankshaft and minimizes installation space. Its position directly in the crankcase means there is no need to seal off the crankshaft, which reduces friction. The spoke damper is already in volume production at Chinese manufacturers, with further production starts set to take place in the course of this year.
To improve engine efficiency without compromising driving dynamics, Schaeffler also offers next-generation camshaft phasing units. These incorporate a brushless DC (BLDC) motor including control unit, integrated electronics, and software for optimized valve control across a wide range of loads and speeds. The high adjustment speed and precision allow for efficient combustion.
Last year, Schaeffler marked the production launch of the latest generation of camshaft phasing units at its plant in Taicang, China, and is supplying customers worldwide.
Growth Segment: Sensor Technology
Thanks to the merger with
in 2024, Schaeffler said it now has a sensor technology portfolio used, for example, in emission control and exhaust gas aftertreatment. For improved emission control when using renewable fuels, Schaeffler offers the Flex Fuel sensor. This high-precision sensor is mounted between the fuel tank and engine and measures the ethanol content in the fuel before it is injected.
“Following our merger with Vitesco Technologies, we have a well-rounded, innovative product portfolio, expanded capabilities in the key R&D segments, an increased global presence, and greater vertical integration,” said Zink. “We are therefore in a good position to work with our customers as a key partner to successfully shape the transformation – in Germany, Europe and worldwide.”
      Searching for a Lexus transmission near me often means finding a dependable replacement that delivers luxury-level performance and smooth shifting. Lexus vehicles share many reliable drivetrain components with Toyota models, making their transmissions highly respected for durability and comfort. Whether you own an RX, ES, IS, GX, or LS model, choosing the right transmission replacement helps maintain premium driving quality. Before purchasing, verify the VIN match, mileage history, and transmission condition to ensure proper compatibility. Many drivers choose tested used transmissions because they provide a more affordable alternative to dealership replacements. A reliable Lexus transmission improves acceleration, fuel efficiency, and long-term performance while preserving the smooth driving experience Lexus owners expect from their vehicles.
      The 2014 Ford Fusion manual transmission offers drivers more control, improved driving engagement, and dependable performance. Manual transmissions are often valued for durability and lower maintenance costs compared to some automatic systems. However, clutch wear and gearbox issues can eventually require replacement.
      Drivers searching for a manual transmission should verify compatibility with the engine and drivetrain. A low-mileage used transmission can restore performance while reducing repair costs. Professional installation is recommended for smooth operation and long-term reliability.
      Turbo Auto Parts supplies quality used manual transmissions for the 2014 Ford Fusion. Their inventory includes inspected units at competitive prices to help customers save money while restoring vehicle performance.
      The 2018 Chevrolet Traverse comes equipped with a 9-speed automatic transmission paired with its 3.6L V6 engine, offering wide gear spacing for both fuel efficiency and highway cruising comfort. Some owners have reported concerns with rough or hesitant shifting, particularly during low-speed acceleration and downshifts — often addressed through GM software updates and transmission fluid changes. Dexron HP is the recommended fluid for this unit. When replacing the transmission, ensure the replacement unit is properly programmed to the vehicle's control modules. Remanufactured 9-speed units provide a dependable, warrantied path to restoring smooth, confident performance in your Traverse. link hidden, please login to view
      Replace your 2014 Nissan Sentra transmission with a quality CVT unit from our trusted inventory. The Continuously Variable Transmission in the 2014 Sentra is known for smooth, fuel-efficient performance. We carry low-mileage, fully tested CVT transmissions sourced from reliable vehicles and reputable suppliers. Each unit is inspected to ensure proper function and long-lasting reliability before shipping. Whether your transmission is slipping, jerking, or has completely failed, we have the right replacement for your Sentra. All purchases include a warranty and fast nationwide shipping for quick turnaround. Contact us today to check availability, confirm compatibility, and get a competitive quote. Get your Nissan Sentra shifting smoothly again with confidence.
      The 2016 Hyundai Elantra offered buyers a choice between a six-speed manual transmission and a six-speed automatic, catering to different driving preferences and lifestyles. The automatic version delivered smooth, predictable shifts suited to daily commuting, while the manual appealed to drivers seeking greater engagement and control. Both options connected to a 2.0-liter four-cylinder engine producing 145 horsepower. Generally well-regarded for reliability, the Elantra's transmissions were largely trouble-free during this era. Minor complaints included occasional hesitation from the automatic during sharp acceleration. Proper maintenance, including regular fluid checks and timely servicing, helped owners enjoy many trouble-free miles from both transmission configurations available that year.
