NTN Corp. has developed a torque calculation method for oil-lubricated ball bearings that increases calculation accuracy by up to 50% at high rotational speeds, according to the company. The technology is being implemented in
proprietary calculation programs to support low-torque bearing design for electric and hybrid vehicle motors and gearboxes.
Product development and technical approach
The method analyzes the raceway surface by separating contact and non-contact regions as balls pass along the raceway. Conventional approaches modeled only the contact region; the new approach incorporates both to quantify torque-generating factors and clarify how each factor contributes to torque increase.
According to
, the result is a formula that holds across a wide range of operating conditions, improving high-speed prediction accuracy. The approach enables faster validation of internal bearing design options targeted at low-torque performance.
Market impact for EV and HEV drivetrains
As EV and HEV programs push higher rotational speeds and tighter energy efficiency targets, accurate torque prediction has become a gating factor for bearing selection and system efficiency. By refining preliminary calculations, the method is intended to support low-torque bearing development for traction motors and gearboxes where oil lubrication and high-speed operation dominate.
The company says the method helps identify which internal design strategies are most effective under specific operating conditions. That capability can reduce design iterations and support more targeted product development for electrified powertrains.
Implications for suppliers and manufacturing strategy
NTN reports the improved calculation accuracy will reduce internal workload and accelerate evaluation and proposal processes for EV bearings. Faster analysis can help supplier engineering teams respond to program timelines and align manufacturing plans with validated designs.
The company also plans to extend the approach to other bearing components, including lubricants and cages, to evaluate their impact on torque. NTN says it is leveraging model-based development to enhance research capabilities and speed development cycles.
Distribution and aftermarket considerations
As low-torque bearing designs developed for high-speed EV applications move toward production, distributors and channel partners should monitor specification updates and application guidance. Improved modeling at the design stage can translate to clearer performance data for cataloging, application engineering, and customer support.
Key takeaway for aftermarket product development
For bearing manufacturers and suppliers serving the aftermarket, NTN’s method highlights a trend toward deeper physics-based modeling to manage torque at high speeds under oil lubrication. More accurate torque prediction during early design can inform product launches, reduce redesign risk, and support supplier strategies in the EV and HEV supply chain.
      link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
      Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
      link hidden, please login to view said. Applications & Coverage
      2011-Up Ford F250, F350 and F450 with 6r140 transmission.  2016-Up Ford E350 and E450 with 6R140 transmission.  Available Part Numbers
      TS-FM1261 (6.2L; 6.8L Gas Engines)  TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs)  TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
      link hidden, please login to view is encouraging industry supporters to participate in its promotional campaign, which combines its ongoing 1969 Pontiac Firebird sweepstakes with a limited-time April giveaway. Throughout April, entrants in the Firebird sweepstakes are automatically entered for a chance to win an Advance Professional Solo Stove Bonfire Fire Pit with Stand. April promotion and giveaway details
      The promotion includes an added incentive: 30% more entries into the Firebird sweepstakes during the campaign period. The flash giveaway winner for the Solo Stove will be selected in early May.
      1969 Pontiac Firebird grand-prize specifications
      The featured grand prize is a restored 1969 Pontiac Firebird finished in Champagne Gold Metallic. It includes a 350-cubic-inch V-8 engine, TH350 automatic transmission, dual exhaust, front power disc brakes, 17-inch Yokohama tires and an updated air conditioning system using R134a refrigerant.
      Mission and entry information
      AACF noted that the April promotion is designed to increase engagement while continuing to raise awareness and support for the foundation’s mission. Participants can enter the sweepstakes online, with proceeds supporting AACF’s efforts to provide financial assistance to automotive aftermarket professionals and their families in times of need.
      For more information or to enter, visit www.aftermarketcharity.org or
      Schaeffler announced its LuK TorCon torque converter product line has expanded with the release of the LuK 8L90 TorCon. The company said the 8L90 TorCon is engineered to outperform rebuilt alternatives up to five times longer.
      Replacement Process and In-House Manufacturing
      Designed to streamline the replacement process, the LuK 8L90 TorCon eliminates the need for model-specific cores that are typically required in torque converter rebuilding. The 8L90 TorCon is in stock and ready for installation.
      link hidden, please login to view said it is manufactured to precise standards using all-new components and advanced manufacturing processes and is designed and built in-house from raw material to final assembly. Materials and Testing
      Featuring LuK friction materials and INA premium thrust bearings, the LuK TorCon is engineered to withstand extreme operating conditions. Its fully furnace-brazed fins improve heat dissipation, reduce wear, and enhance long-term durability. The contamination-free manufacturing process includes 100% pressure and lockup testing, along with precision balancing, according to the company.
      Applications and VIO
      The LuK TorCon product line supports a broad range of applications for passenger cars and pickup trucks. Schaeffler said its expertise in manufacturing OE torque converters allows it to capture several applications through a single SKU.
      The TorCon (TC0020) is compatible with select 2015 to 2022 General Motors trucks, vans and SUVs equipped with 8L90 transmissions. It covers multiple engines and has a current VIO of over 700,000, offering versatility when choosing a new torque converter.
      link hidden, please login to view plans to release additional SKUs in the coming months.
      Schaeffler announced its LuK TorCon torque converter product line has expanded with the release of the new LuK 6R80 TorCon. The company said it’s engineered to outperform rebuilt alternatives up to five times longer. Schaeffler added that the 6R80 is built from new, original components and is never remanufactured.
      Simplifies Replacement and Stocking
      link hidden, please login to view said the LuK 6R80 TorCon is designed to simplify the replacement process by eliminating the need for model-specific cores that are often required in torque converter rebuilding. Distributors and installers can rely on the 6R80 TorCon to be in stock and ready for installation, according to the company. Materials, Construction and Testing
      Featuring LuK friction materials and INA thrust bearings, Schaeffler said the LuK TorCon is designed to withstand demanding conditions. Its fully furnace-brazed fins improve heat dissipation, reduce wear, and enhance long-term durability. The contamination-free manufacturing process includes 100% pressure and lockup testing, along with precision balancing.
      Applications and Coverage
      The LuK TorCon product line covers applications for passenger cars and pickup trucks. The line captures several applications through a single SKU. The TorCon (TC0019) is compatible with select 2014–2020 Ford F-150 trucks and Transit vans equipped with 6R80 transmissions, covers multiple engines, and has a current VIO of over 2,800,000. In the coming months,
      link hidden, please login to view said it will release additional SKUs. The post
