has launched an expanded steering and suspension range. It provides extensive application coverage for major original equipment (OE) car and truck manufacturers. The offering includes ball joint kits, track control arms, stabilizer links, silent blocks, steering boots, tie rod ends, axial joints, rod assemblies, rear suspension arm kits and suspension repair kits. These components are designed with OE-quality materials to ensure optimal performance and safety, according to SKF.
Product Development
The steering and suspension components incorporate SKF’s proprietary high-performance synthetic grease, specifically formulated to minimize friction and “stick slip.” This technology promotes smooth system movement and a responsive steering experience, contributing to a longer lifespan for these components.
Market Impact
By reducing friction and the “stick slip” effect by up to 35%, SKF components offer improved driving comfort, vehicle response and safety, the company said. These enhancements lead to smoother handling and better maneuverability, which are crucial for driver confidence across varying road conditions.
Distribution Strategy
SKF commits to supporting auto service professionals with simplified installation processes. Installation guidelines and service bulletins are accessible via QR codes on product packaging. This facilitates easy access to technical support and ensuring reliable, long-life performance of the product line.
Johannes Deeg,
product line manager of steering and suspension, said, “SKF’s Steering and Suspension components have been tested at SKF facilities worldwide to ensure they meet the high-quality material and performance standards of OE car and truck manufacturers.”
      Published by GreenGears Auto  |  6 min read  |  Steering Parts Buying Guide
      Search our
      🛡️ 15-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns  ·  📋 Mileage Verified
      Published by GreenGears Auto  |  10 minute read  |  Steering Repair & OEM Parts Guide
      Steering problems are never optional repairs. A vehicle that pulls to one side, wanders at highway speed, feels heavy or vague through the wheel, or makes knocking and groaning noises during turns is telling you that a critical safety system is compromised. Steering component failures affect braking performance, tyre wear, and directional control simultaneously — making them among the highest-priority repairs on any vehicle. At GreenGears Auto, we stock quality-inspected OEM used steering components across every major platform — the exact parts your vehicle was engineered around, at 50–70% less than new OEM pricing. This guide maps every common steering problem to the specific replacement part responsible, with platform-specific sourcing guidance and diagnosis support.
      Why Steering Problems Demand OEM Parts
      Steering is the most feedback-sensitive system on any vehicle. Every component — from the steering rack ratio to the tie rod end ball joint preload to the column intermediate shaft angle — is engineered as an integrated system tuned specifically for your vehicle's weight, suspension geometry, and handling balance. When any part of that system is replaced with a component that deviates from OEM specification, the result is detectable immediately: steering that feels heavier, lighter, vaguer, or simply different from the original design intent.
      35% Of steering repair comebacks involve an aftermarket part that failed to replicate OEM steering feel or caused premature wear 50–70% Average savings on OEM used steering components vs. new OEM dealer pricing at GreenGears Auto #1 Reason steering problems accelerate tyre wear — misalignment caused by worn steering components   ⚠️ Steering Problems Are Safety-Critical — Never Delay Unlike a noisy suspension bushing or a leaking differential seal, a failing steering component directly compromises your ability to control the vehicle in an emergency. Loose tie rod ends, worn steering racks with excessive play, and seized steering columns are not "monitor and watch" repairs. Any steering symptom that affects directional stability, pull, or play in the wheel requires immediate diagnosis and repair.
      Steering System Types — What Your Vehicle Uses
      Identifying your vehicle's steering system type is the first step to sourcing the correct replacement part. Modern vehicles use one of three primary steering system designs, and replacement parts are not interchangeable across systems.
      🔧Hydraulic Power Steering (HPS) Uses a belt-driven hydraulic pump to provide steering assistance. Common on vehicles built before 2012 and many trucks through 2020. Components include the power steering pump, steering rack with hydraulic assist, high-pressure hoses, and fluid reservoir. Failure symptoms include whining, heavy steering, and fluid leaks.
      ⚡Electric Power Steering (EPS / EPAS) Uses an electric motor — either column-mounted or rack-mounted — to provide steering assistance. Standard on virtually all new vehicles since 2015. No hydraulic fluid required. Failure symptoms include loss of power assist, steering fault warning lights, and inconsistent steering weight. Requires exact OEM replacement for ECU integration.
      🔩Recirculating Ball Steering Gearbox Used on body-on-frame trucks and SUVs — Ford F-Series (pre-2021), Chevrolet Silverado / Suburban, Ram 1500/2500/3500, Toyota Tundra / Land Cruiser. Uses a steering gear box rather than a rack-and-pinion. Common failure points include sector shaft wear, worm gear wear, and output shaft seal leaks.
      🎯Rack-and-Pinion Steering The most common steering system on unibody cars, crossovers, and most modern SUVs. A rotating pinion gear meshes with a linear rack to convert steering wheel rotation into lateral wheel movement. Both hydraulic and electric power assist versions exist. Failure symptoms include clunking, looseness, and fluid leaks at the rack boots.
      Steering Problem Symptoms — Matched to Failed Components
      Every steering problem has a mechanical source. Matching your specific symptom to the component responsible before ordering parts is the fastest and most cost-effective path to a correct repair.
      🔄 Pull or Drift
      Pulls consistently to one side → Tie rod end or steering rack worn on that side Pulls under braking → Brake or suspension issue (confirm before steering diagnosis) Wanders at highway speed → Worn rack, loose tie rod ends, or worn steering shaft Pull that changes with road surface → Inner tie rod end worn Torque steer under acceleration → CV axle or engine mount (not steering) 💥 Knock & Clunk
      Clunk when turning over bumps → Tie rod end or steering rack mount Knock at centre of steering → Steering column intermediate shaft U-joint Clunk turning at low speed → Outer tie rod end ball joint worn Knock from steering rack area → Rack mount bushings worn Clunk on full lock → CV axle or inner tie rod end ⚖️ Heavy or Light Steering
      Heavy steering throughout → Power steering pump failure (HPS) or EPS motor fault Heavy on one side only → Rack internal damage or binding Steering suddenly heavy → HPS pump belt or fluid loss; EPS fault code Steering too light / vague → EPS torque sensor calibration or rack wear Heavy only when cold, eases when warm → HPS pump or fluid viscosity issue 🎮 Excessive Play or Looseness
      Play in wheel before wheels respond → Worn steering rack, loose column shaft Play that worsens over bumps → Inner tie rod end worn Dead zone around centre → Steering rack internal wear (teeth stripped) Play only in one direction → Asymmetric rack wear or sector shaft (gearbox) Play at wheel felt at tyre → Ball joint or steering knuckle (not steering) 🔊 Whine & Groan
      Whine that increases with steering angle → HPS pump cavitating (low fluid) Groan on full lock → HPS pump relief valve or low fluid level Whine that changes with engine speed → HPS pump bearing worn No whine but heavy steering → EPS motor fault (no hydraulic noise) Groan when parking slowly → Worn steering rack or column bearing ⚡ Warning Lights & Electronics
      EPS / Power Steering warning light → EPS motor, torque sensor, or control module Steering light + traction control fault → EPS module communicating with ESC Steering angle sensor fault → Steering angle sensor in column or rack ADAS lane keeping fault + steering light → EPS calibration or rack replacement needed Intermittent power assist loss → EPS wiring harness or module fault
      Top OEM Replacement Parts for Steering Problems — By Component
      Here is every major steering system component that drives replacement decisions — what it does, what symptoms it causes when it fails, and the best OEM used sourcing approach for each platform.
      🏆 Highest-Cost Steering Repair Rack-and-Pinion / EPS Rack Steering Rack & Pinion Assembly (Hydraulic & Electric)
      OEM Used Price: $120–$680 Symptoms: Play / Clunk / Pull / Wander The steering rack is the central component of rack-and-pinion steering — converting the rotational input from the steering wheel into the lateral movement that steers the front wheels. It is the most expensive individual steering repair on most platforms, and the component most frequently misdiagnosed when the actual fault lies with an inner tie rod end, rack mount bushing, or steering shaft. On electric power steering (EPS) vehicles, the steering rack incorporates the electric assist motor and torque sensor — making exact OEM specification non-negotiable for correct integration with the vehicle's stability control and ADAS systems.
      When does the steering rack actually need replacement?
      Measurable play at the steering wheel that persists after tie rod end inspection — excessive rack internal wear (stripped rack teeth or worn pinion) Active fluid leak from the rack boots or hydraulic cylinder ends (hydraulic rack) Confirmed EPS motor or torque sensor failure where the motor is integrated into the rack assembly and cannot be replaced separately Physical impact damage to the rack housing or internal components from a collision Best used OEM steering rack units by platform:
      Honda Accord / CR-V EPS rack (2013–2022): Electric power steering rack — most available EPS rack unit in the used market due to Honda's enormous sales volume; $120–$280; confirm column-assist vs. rack-assist EPS design Toyota Camry / RAV4 EPS rack (2012–2022): Column-assist EPS on Camry; rack-assist on RAV4; both widely available from accident-damaged low-mileage donors; $140–$320 Ford Fusion / Edge / Explorer EPS rack (2013–2020): Rack-mounted EPS motor design — most available Ford EPS rack in the used market; $160–$380; confirm 2WD vs. AWD rack specification Chevrolet Malibu / Equinox EPS rack (2013–2018): Column-assist EPS; $120–$280; shares architecture across Malibu and Equinox on same generation — expands sourcing options BMW 3 Series / 5 Series EPS rack (F30/F10, 2012–2019): Rack-mounted EPS motor with integrated torque sensor; $280–$580; requires alignment and may need EPS calibration after replacement Subaru Outback / Forester EPS rack (2015–2022): EyeSight camera system integration on equipped models requires post-replacement calibration; $180–$360 🔧 EPS Steering Rack — OEM Is Non-Negotiable Electric power steering racks contain integrated torque sensors and motor controllers calibrated to the vehicle's specific EPS control module. Aftermarket EPS racks frequently fail to communicate correctly with the vehicle's ECU — producing steering fault lights, inconsistent assist levels, and in some cases disabling stability control integration. OEM used is the only reliable option for EPS rack replacement.
      🔗 Most Frequently Replaced Steering Part Inner & Outer Tie Rod Ends
      Tie Rod Ends — Inner & Outer
      OEM Used Price: $30–$90 per end Symptoms: Knock / Pull / Rapid Outer Tyre Wear Tie rod ends are the final mechanical link in the steering chain — connecting the steering rack to the steering knuckle at the wheel. The outer tie rod end is the most commonly replaced steering component across all platforms, failing through ball joint wear that produces a knock over rough surfaces and a progressive steering looseness that is most noticeable at highway speed. The inner tie rod end (or inner tie rod) connects the outer end to the rack itself and fails less frequently — but when it does, it produces a more pronounced play that is felt as a vague, floating response around the steering centre position.
      Outer tie rod end failure produces a knock during steering input over bumps and a pull that may change with road surface — the lateral load variation exposes the worn ball joint Inner tie rod end failure produces play that worsens when the steering is loaded sideways — a lateral push-pull test on the tyre while someone watches the rack boot should reveal inner tie rod movement Always replace outer tie rod ends in pairs — if one side has failed, the opposite is at the same mileage and should be replaced simultaneously to preserve steering balance A 4-wheel alignment is mandatory after any tie rod end replacement — wheel toe will have shifted from the worn end geometry OEM tie rod ends use factory ball joint preload matched to your vehicle's steering feel calibration — aftermarket ends with different preload alter steering weight and feedback in ways that are immediately noticeable Inspect the dust boot condition before purchasing a used tie rod end — a torn or missing boot means the joint has been running contaminated and dry, accelerating internal wear High-frequency platforms: Toyota Camry (front), Honda Accord (front), Ford Fusion / F-150 (front), Chevrolet Silverado (inner and outer), Nissan Altima / Maxima (outer) — all see high outer tie rod end failure rates at 80,000–120,000 miles.
      ⚙️ HPS System Heart Hydraulic Power Steering
      Power Steering Pump (Hydraulic)
      OEM Used Price: $60–$220 Symptoms: Whine / Heavy Steering / Fluid Leak The hydraulic power steering pump is a vane or gear pump driven by the engine accessory belt that generates the hydraulic pressure used to assist steering effort. Power steering pump failure is the most common hydraulic steering system repair — producing a distinctive whining noise that increases with steering angle, heavy steering effort (particularly when parking), and in advanced cases, fluid leaks from the pump body or pressure fittings. The whine is most noticeable on cold starts and diminishes as the fluid reaches operating temperature.
      Power steering pump whine that is present only at startup and disappears at operating temperature typically indicates low fluid or a deteriorating pump — check fluid level and condition before ordering a pump Whine that is present at all temperatures and increases with steering angle indicates the pump itself is failing — internal vane or gear wear is reducing pressure output OEM power steering pumps are engineered to the specific flow and pressure requirements of your vehicle's steering rack — an over-pressure aftermarket pump damages the rack seals; an under-pressure pump produces insufficient assist Always replace the power steering pump reservoir and filter when replacing the pump — contaminated fluid from the failed pump will rapidly damage a new or used replacement Flush and refill the power steering system with the correct OEM-specified fluid after pump replacement — using generic power steering fluid in a vehicle that specifies Honda PSF or Pentosin causes premature seal failure High-frequency platforms: Honda CR-V / Accord V6 (pre-2013), Toyota Highlander / Sienna (pre-2013), Ford F-150 / Explorer (pre-2011), Chevrolet Tahoe / Silverado (pre-2014), Nissan Titan / Armada — all see high hydraulic pump failure rates at 100,000–150,000 miles.
      ⚡ EPS System Core Electric Power Steering
      Electric Power Steering (EPS) Motor, Column & Control Module
      OEM Used Price: $120–$480 Symptoms: EPS Warning Light / Loss of Assist / Fault Codes Electric power steering (EPS) systems have replaced hydraulic power steering on virtually every new vehicle since 2015. Instead of a hydraulic pump and pressurised fluid, an electric motor — mounted either on the steering column or directly on the rack — provides variable steering assistance managed by an EPS control module. When EPS components fail, the result ranges from a persistent warning light with reduced assist to complete loss of power steering assistance. Because the EPS system communicates with the vehicle's stability control, lane-keeping assist, and autonomous braking systems, OEM replacement is critical — aftermarket EPS components introduce calibration errors that cascade into ADAS faults.
      EPS failure types and the OEM used parts that fix them:
      Column-assist EPS motor failure: The electric motor and torque sensor are integrated into the steering column — replacement requires the complete column assembly or, on some platforms, the motor and sensor as a unit; most common on Toyota, Honda, and GM column-EPS platforms Rack-assist EPS motor failure: The electric motor is mounted on or integrated into the steering rack — rack replacement is required when the motor cannot be separated; most common on Ford, BMW, and Subaru rack-EPS platforms EPS torque sensor fault: The torque sensor measures steering wheel input force and direction — a failed sensor produces erratic assist levels and fault codes; on column-EPS designs it is part of the column assembly; on rack-EPS designs it is integrated into the rack EPS control module fault: The EPS ECU manages motor output based on vehicle speed, steering angle, and torque sensor input — module faults produce the EPS warning light without mechanical component failure; used OEM modules require programming to the vehicle on some platforms ⚠️ EPS Replacement and ADAS Recalibration On vehicles equipped with lane-keeping assist, automatic emergency steering, or any other ADAS steering function, replacement of any EPS component — column, rack, motor, or module — requires a steering angle sensor calibration and in many cases a full ADAS camera and radar recalibration. Factor this into the total repair cost before starting the job. GreenGears Auto's parts specialists can confirm which calibration steps your specific vehicle requires.
      🔗 Driver Interface Component Steering Column Assembly
      Steering Column Assembly & Intermediate Shaft
      OEM Used Price: $80–$380 Symptoms: Knock at Centre / Tilt or Telescoping Failure / EPS Fault The steering column connects the steering wheel to the steering rack or gearbox via a series of shafts and U-joints, incorporating the tilt and telescoping adjustment mechanism, the clock spring (airbag slip ring), the ignition switch, and — on column-EPS vehicles — the electric assist motor and torque sensor. Steering column problems are often overlooked because the symptoms they produce (a knock when turning over bumps, a grind during tilt adjustment, or intermittent EPS faults) are frequently attributed to other components.
      The intermediate shaft: The steering intermediate shaft — the coupling between the column and the rack or gearbox — is one of the most commonly missed steering noise sources. Its U-joints absorb the angle between the column and rack and transmit steering input without backlash. Worn intermediate shaft U-joints produce a distinctive clunk or knock when turning the steering wheel in slow parking manoeuvres that is almost universally misdiagnosed as a tie rod end or rack mount problem.
      Intermediate shaft U-joint wear is confirmed by having someone slowly turn the steering wheel while you observe the shaft under the bonnet — visible movement or audible knock at the U-joint confirms the diagnosis On column-EPS vehicles, the complete column assembly includes the EPS motor and torque sensor — always confirm whether your fault is mechanical or electronic before ordering Tilt and telescoping column mechanism failures are almost always best addressed with a used OEM column assembly rather than individual mechanism repair Clock spring (steering wheel slip ring) failure produces airbag warning lights and disabled horn or paddle shifters — confirm clock spring condition before attributing electrical faults to the column structure OEM used steering columns from low-mileage accident donors are excellent quality — the column is one of the least wear-prone components in a low-speed or front-impact collision if the impact axis is not directly through the column
      🔩 Body-on-Frame Trucks & SUVs Recirculating Ball Gearbox
      Steering Gear Box (Recirculating Ball)
      OEM Used Price: $120–$480 Symptoms: Play / Wander / Leak at Output Shaft Body-on-frame trucks and SUVs use a recirculating ball steering gearbox rather than a rack-and-pinion — a more robust design suited to the higher loads of truck and SUV applications. The steering gearbox converts steering wheel rotation into lateral output shaft movement via a worm gear and recirculating ball nut. Gearbox wear produces a dead zone around the steering centre — a small amount of steering wheel movement that produces no wheel response — and a wander or looseness at highway speed that is the most common steering complaint on high-mileage trucks.
      Steering gearbox play is measured at the pitman arm end of the output shaft with a dial indicator — compare to the manufacturer's maximum allowable play specification before condemning the unit Some steering gearbox play is adjustable via the sector shaft adjustment screw — always attempt adjustment before replacement; a correctly adjusted used gearbox from a quality donor vehicle will often outlast a remanufactured unit OEM used gearboxes from low-mileage donor trucks are the best replacement option — remanufactured units frequently use the original worn housing with new internals, producing a gearbox that is no tighter than the original after a short break-in period Always replace the output shaft seal when replacing a steering gearbox — this is the most common fluid leak point and is inaccessible with the pitman arm installed High-frequency platforms: Ford F-150 / F-250 / F-350 (pre-2021), Chevrolet Silverado / Suburban / Tahoe, GMC Sierra / Yukon, Ram 1500 / 2500 / 3500 (pre-2019), Toyota Tundra / Sequoia (pre-2022), Nissan Titan / Armada.
      🔗 Structural Steering Component Steering Knuckle / Spindle
      Steering Knuckle Assembly
      OEM Used Price: $80–$300 Symptoms: Alignment Impossible / Vibration / Post-Collision The steering knuckle is the precision-machined casting at the wheel corner that connects the hub bearing, ball joint, tie rod end, brake caliper, and strut mount into a single structural assembly. Steering knuckles are not wear items under normal use — they are replaced after collision damage, severe corrosion, or structural fatigue from repeated high-stress impacts. However, when knuckle replacement is required, it is one of the most expensive individual steering repair components new — making used OEM sourcing particularly compelling.
      Even minor distortion of the steering knuckle — as little as 0.5mm deviation from true — makes correct four-wheel alignment impossible regardless of adjustment; if alignment cannot be achieved within specification after other repairs, knuckle damage should be suspected OEM used knuckles are the most cost-effective option by a very wide margin — new OEM knuckles are expensive and aftermarket knuckles frequently have dimensional deviations that compromise alignment FWD, RWD, and AWD variants of the same vehicle use different knuckles — confirm drivetrain configuration before ordering; AWD knuckles have different hub bearing flange and axle shaft clearance specifications Always source the knuckle from a vehicle with the same brake and ABS configuration — knuckles vary by brake rotor size, caliper mount dimensions, and ABS sensor location Inspect all mounting surfaces carefully — the strut pinch bolt area, ball joint seat, and tie rod boss must all be undamaged and dimensionally correct for proper component installation
      💧 HPS Leak Repair Hydraulic Lines & Hoses
      Power Steering Hoses & High-Pressure Lines
      OEM Used Price: $25–$90 per hose Symptoms: Power Steering Fluid Leak / Low Fluid Warning Power steering hoses — both the high-pressure line from the pump to the rack and the low-pressure return line — are a frequent source of hydraulic power steering fluid leaks on high-mileage vehicles. The high-pressure hose degrades at the rubber-to-metal fittings and at the hose body itself from heat cycling and ozone exposure. A leaking power steering hose is one of the most misdiagnosed fluid leak sources — often confused with an engine oil or coolant leak because the reddish ATF-based power steering fluid can travel from its leak source along wiring harnesses, intake hoses, and heat shields before dripping to the ground.
      Always pressure-wash the engine bay and drive the vehicle before tracing a power steering leak — the actual leak source is often 6–12 inches from where the fluid drips OEM power steering hoses use crimped metal fittings matched to the pump and rack port thread specifications — aftermarket hoses with generic fittings frequently weep at the connections Replace both high-pressure and low-pressure hoses simultaneously — if the high-pressure hose has degraded from heat and age, the return line is at equivalent mileage and condition Flush and refill the power steering system after hose replacement — any air introduced during hose disconnection must be purged to prevent pump damage and steering noise
      🔩 Truck Steering Linkage Steering Linkage Components
      Pitman Arm, Idler Arm & Centre Link (Drag Link)
      OEM Used Price: $40–$160 per component Symptoms: Wander / Shimmy / Excessive Play Body-on-frame trucks and SUVs with recirculating ball steering gearboxes use a parallelogram steering linkage rather than the direct rack-and-pinion connection of unibody vehicles. This linkage consists of the pitman arm (connected to the gearbox output shaft), the idler arm (the mirror-image pivot on the passenger side), the centre link (the long bar connecting both), and the tie rod ends at each wheel. Any worn component in this linkage system introduces play and causes the shimmy and wander that are the most common steering complaints on high-mileage trucks and body-on-frame SUVs.
      Idler arm wear is the most common cause of steering shimmy and wander on high-mileage body-on-frame vehicles — it is the highest-wear linkage component because it carries the full lateral load of the centre link without the gearbox's mechanical advantage Pitman arm wear is less common than idler arm wear but produces a more severe steering looseness because it is the first link in the steering chain — even small pitman arm play amplifies through the entire linkage Always replace idler arm and pitman arm simultaneously when worn — restoring one side of the parallelogram linkage while leaving the other worn produces uneven steering response that is as frustrating as the original fault Inspect the drag link (centre link) for wear at the ball socket ends — a worn drag link ball socket produces the same shimmy symptoms as an idler arm but is less commonly inspected
      OEM Used vs. Aftermarket for Steering Repairs
      Steering is the system where OEM specification matters most. Aftermarket steering components produce a higher rate of comebacks, noise complaints, and alignment instability than any other repair category — because steering feel is exquisitely sensitive to small deviations from OEM geometry, preload, and component stiffness.
      🏭 Aftermarket Steering Parts
      Tie rod end ball joint preload frequently differs — changes steering weight from day one EPS racks often fail to communicate with vehicle ECU — fault codes and reduced assist common Steering rack internal gear tolerances may vary — play develops faster after installation Power steering pump flow/pressure may not match rack specifications — damages seals Steering column EPS motors frequently misfire on torque sensor calibration — assist inconsistency Knuckle casting dimensions often deviate — alignment impossible to achieve within spec 35% of steering noise comebacks involve aftermarket parts that failed NVH replication ♻️ OEM Used — GreenGears Auto
      Factory ball joint preload — original steering feel preserved from day one OEM EPS calibration intact — full ECU integration and ADAS compatibility Factory rack internal tolerances — correct play specification maintained OEM pump flow matched to rack — correct pressure, no seal damage Original EPS torque sensor calibration — consistent, predictable assist Factory knuckle dimensions — alignment achievable within OEM specification Mileage-verified from documented low-mileage donor vehicles
      Steering Replacement Parts Quick Reference
      Component Primary Symptom OEM Used Price Replace in Pairs? Alignment After? Priority Outer Tie Rod Ends Knock / pull / tyre wear $30–$90 ea Yes — always Yes — mandatory 🔴 High Inner Tie Rod Ends Play / wander at centre $35–$80 ea Yes — recommended Yes — mandatory 🔴 High Steering Rack (HPS) Play / leak / wander $120–$420 N/A Yes — mandatory 🔴 High Steering Rack (EPS) EPS fault / assist loss $160–$680 N/A Yes + ADAS cal. 🔴 Critical Power Steering Pump (HPS) Whine / heavy steering $60–$220 N/A No 🟠 Medium-High EPS Column / Motor EPS warning / assist loss $120–$480 N/A Yes + calibration 🔴 Critical Steering Gear Box Play / wander (trucks) $120–$480 N/A Yes — recommended 🔴 High Steering Column Knock / tilt failure $80–$380 N/A Angle sensor reset 🟠 Medium-High Intermediate Shaft Knock — parking turns $40–$120 N/A No 🟡 Medium Steering Knuckle Alignment impossible $80–$300 N/A Yes — mandatory 🔴 High Power Steering Hoses Fluid leak $25–$90 ea Yes — recommended No 🟡 Medium Idler Arm / Pitman Arm Shimmy / wander (trucks) $40–$160 ea Yes — both together Yes — recommended 🔴 High
      What to Check When Buying Used OEM Steering Parts
      Confirm Steering System Type and Assist Method
      HPS and EPS racks are completely different components even on the same nameplate. A 2012 Honda Accord uses hydraulic power steering; a 2013 Accord uses EPS. A 2014 Toyota Camry uses column-assist EPS; a 2015 RAV4 uses rack-assist EPS. Always confirm the steering system type for your specific model year before ordering — the wrong type cannot be made to work regardless of how it is modified. Inspect Tie Rod End Boot Condition
      A torn, cracked, or missing boot means the ball joint inside has been running exposed to road contamination — moisture, grit, and road chemicals accelerate internal wear significantly. A used tie rod end with an intact, pliable boot that still contains grease is a high-quality find. Reject any tie rod end with a compromised boot regardless of asking price. Check Rack Boots for Fluid Saturation (HPS Racks)
      On hydraulic power steering racks, inspect the rubber rack boots at both ends. Fluid-saturated, collapsed, or torn boots indicate that the internal rack seals have been leaking — the rack may have been operating with reduced hydraulic fluid and potential internal contamination. A dry, intact boot confirms the rack seals have been maintaining correct fluid containment. Verify Donor Mileage and Vehicle History
      Steering components from low-mileage donor vehicles retain the most remaining service life. A steering rack from a 35,000-mile accident-damaged vehicle is a very different purchase from one pulled off a 100,000-mile high-mileage donor. GreenGears Auto documents and verifies donor mileage on every steering component listing. Confirm Exact Application — Trim and Drivetrain
      Steering racks, knuckles, and linkage components vary by trim level, drivetrain, brake package, and sometimes engine in ways that are not obvious from the exterior. An AWD steering knuckle is different from a 2WD knuckle. A Sport trim steering rack may have a different ratio from a base trim. Always provide the full year, make, model, trim, engine, and drivetrain when ordering steering components from GreenGears Auto.
      Always Do This After Steering Repairs
      Steering repairs have mandatory post-installation steps that are as important as the repair itself. Skipping these steps produces an unsatisfactory repair regardless of the quality of the replacement part.
      Perform a full 4-wheel alignment after any repair involving tie rod ends, steering rack, steering knuckle, or control arms — wheel toe, camber, and caster will have shifted and must be reset to OEM specification On EPS vehicles, perform a steering angle sensor calibration using a scan tool after any steering column, rack, or knuckle replacement — an uncalibrated steering angle sensor produces incorrect ESC intervention and may disable ADAS features On vehicles with lane-keeping assist, automatic emergency braking, or any ADAS steering function, a forward-facing camera recalibration is required after EPS rack or column replacement — the camera baseline changes with any steering geometry change After hydraulic power steering pump replacement, bleed and purge the power steering system with the wheels on full lock in each direction — trapped air causes pump damage and noise After steering gearbox replacement on trucks, check and adjust the steering column shaft angle to ensure no binding through the full steering range before the vehicle leaves the shop Road test at highway speed before completing the repair — any residual pull, wander, or vagueness detected at speed is far cheaper to address with the alignment equipment still set up than after the customer takes delivery Inspect adjacent components — ball joints, control arm bushings, and wheel bearings — while the steering system is already disassembled; worn adjacent components cause premature wear on the new steering part and will require re-disassembly soon   ✅ GreenGears Auto's Steering Parts Promise Every OEM used steering component in our inventory — racks, pumps, columns, tie rod ends, knuckles, and linkage — is inspected for boot condition, housing integrity, mounting surface condition, and documented donor mileage before listing. We confirm steering system type and trim-specific fitment on every order. Each component is backed by our
       15 to 90-day satisfaction guarantee with free US shipping in 3–7 days.
      Need OEM Replacement Parts for a Steering Problem?
      Tell us your year, make, model, trim, steering system type, and the symptom you're experiencing — our steering parts specialists will identify the exact OEM used component and get it to you in 3–7 days with free US shipping.
      ✅ OEM Verified 🚚 Free US Shipping ↩️ 15-Day Returns 📋 Mileage Documented link hidden, please login to view
      International Lubricants, Inc. (ILI), makers of LUBEGARD automotive lubricants, announced the introduction of LUBEGARD Multi-System Friction Modifier Additive #42004 (4-ounce) for differentials, transmissions and transfer cases. ILI said its low-odor formula makes it suitable for workplaces, including confined environments.
      Compatibility
      The company added that LUBEGARD Multi-System Friction Modifier eliminates chatter and shudder and is compatible with all OEM friction modifiers, including Ford XL-3, GM 88900330 and Chrysler MS 10111. It is effective in eliminating torque converter shudder in automatic transmissions, including 8- to 10-speed.
      Formulated for performance and component life
      link hidden, please login to view upgrades automatic transmission fluid (ATF), gear oil or transfer case fluid without affecting the viscosity grade. According to ILI, it is formulated with a proprietary ester-based, synthetic, heat-resistant friction modifier and anti-wear additive for long-lasting performance and component life. The post
      As part of its ongoing commitment to continuous improvement,
      link hidden, please login to view has introduced an updated label design for our larger (non-graphic) kraft boxes. The change will be implemented as a running update across production. The new label format features a cleaner, more streamlined layout with enhanced readability. Key product information, especially part numbers, is now more prominent and easier to identify at a glance, Anchor said. These improvements are designed to help simplify product handling and identification for distributors, warehouse teams, and end users alike.
      In addition to improved functionality, the updated labels provide a more consistent and professional presentation throughout the distribution chain, supporting more efficient inventory management and product visibility on shelves and in storage, added
      link hidden, please login to view. During the transition period, customers may receive shipments with either the current or the updated label design as inventory cycles through. The product, part numbers and packaging specifications remain unchanged; only the label design has been updated.
