Hemric Scores Strong Points Day at Charlotte ROVAL
By NAPA
Chase Elliott qualified 18th for Sunday’s NASCAR Cup Series race at Bristol Motor Speedway. Elliott finished the first stage in 16th and followed that up with a 13th-place finish in stage two. In the final stage, the 30-year-old driver avoided damage after a late-race spin and ultimately finished 22nd. Elliott leaves Bristol fifth in the Cup Series points standings, 122 markers behind the leader. Chase Elliott and the No. 9
link hidden, please login to view team qualified 18th for Sunday’s NASCAR Cup Series race at Bristol Motor Speedway. The 30-year-old gained ground on the initial start of the race but got stuck in the top lane before clearing down into the 21st position on lap eight. Elliott was running in that same spot when the first caution of the race came out on lap 62. The team ultimately decided not to pit in order to gain track position. With everyone ahead of him pitting, Elliott led the field back to green on lap 71. He held strong inside the top five until slipping to sixth on lap 106. As the run went on, Elliott fought hard for position before fading outside the top 10, ending the first stage in 16th place. Under the stage-ending caution, Elliott reported that he “overbuilt the right rear and was hanging on from there.” Crew chief Alan Gustafson called him to pit road for four fresh tires and fuel.
Elliott started stage two in 14th on lap 137 and improved to 13th before the yellow flag was displayed for an incident on lap 144. Staying out, Elliott opted for the inside of row six for the lap-152 restart. He continued to run inside the top 15 and was scored in 13th when the race was slowed for a caution on lap 160. Elliott relayed that the No. 9 NAPA Auto Parts Chevrolet was “borderline a little snug, especially on the bottom.” The team opted not to pit, along with a majority of the field, and Elliott restarted 13th on lap 169. The 2020 Cup Series champion worked his way to 11th on lap 188 before ending the second stage in 13th on lap 250. Elliott brought his No. 9 Chevy to the attention of his crew for four tires, fuel and an air-pressure adjustment to try to improve the handling.
A fast pit stop put Elliott in 11th for the choose. He opted to start the final stage from the outside of row six. He continued to run inside the top 12 until slipping to 13th on lap 271. Elliott reported a loose handling condition during the run. When a caution came out on lap 312, he was scored in 19th. The team reversed the air-pressure adjustment during the pit stop for four tires and fuel. Elliott restarted 17th on lap 321 and was running in the same position when the yellow flag was displayed on lap 381. He reported the handling was “in a better place.” Elliott visited pit road for four tires, fuel and a slight air-pressure adjustment under the caution. He was 15th to choose his lane, deciding on the outside. Elliott gained positions on the restart, advancing as high as 12th.
He was running in 14th when the No. 9 NAPA Auto Parts Chevy got loose on lap 421, but Elliott was able to save it. Over the course of the run, Elliott faded to 18th and went a lap down on lap 447. He did manage to gain a position, but then got loose and spun on lap 477, bringing out the caution. Elliott was able to avoid damage in the spin. He brought the No. 9 Chevy to pit road for four tires and fuel. He restarted 22nd and was up to 21st when another incident slowed the race with fewer than five laps to go, sending the race into overtime. Elliott tried to gain ground in the closing laps before ultimately finishing the race in 22nd.
Elliott is now fifth in the Cup Series points standings, 122 markers behind the leader.
Start / Finish: 18 / 22
Points Standing / Total: 5th / 264 pts. (-122)
Next Race: Sunday, April 19, Kansas Speedway
How to Watch or Listen: 2:00 p.m. ET on FOX, SiriusXM or MRN
NAPA:
Chase Elliott: link hidden, please login to view
Hendrick Motorsports: link hidden, please login to view
No. 9 Team: link hidden, please login to view The post
By NAPA
Daniel Hemric came from deep in the field and overcame a late tire rub to rally and finish 12th at Bristol Motor Speedway on Friday night. The driver of the No. 19 Arnott Suspension Products Chevrolet Silverado RST clawed back from 23rd position after an unscheduled pit stop to slice his way to 12th position. The effort netted Hemric two positions in the NASCAR CRAFTSMAN Trucks Series standings and closed the gap to the provisional Chase cut line.
Hemric took the green flag from 23rd under clear evening skies in “Thunder Valley.” After gaining a pair of positions in the first 15 laps, Hemric reported his Arnott Suspension Products Chevrolet was “free, but not bad.” He briefly climbed to 19th on the lap-23 restart but was trapped on the outside groove and ultimately closed out Stage 1 in 22nd on lap 65.
Crew chief Kevin Bellicourt armed Hemric with four tires, fuel, and an air pressure change during the first stage caution as the No. 19 subsequently restarted 22nd on lap 79. He instantly grabbed five positions on the restart and held that spot until a caution on lap 117, 13 circuits shy of the second stage break. Hemric pitted with the majority of the field and was officially scored 21st at the end of Stage 2 following a brief, three-lap run.
Hemric quickly cracked the top-15 by lap 155 to start the final segment but sustained minor damage to the left side bodywork on lap 156 when the No. 13 spun beside him and triggered a tire rub. The team’s concern for the left rear tire was great enough to bring Hemric to pit road under a caution on lap 168 to pit for left side tires and clearance the fender. He restarted 23rd with cooler tires and took full advantage over the final 80 laps. He rejoined the top-15 by lap 202 and capitalized on the final 27-lap run of the evening to advance to 12th at the checkered flag.
“That was a hard night’s work to finish 12th,” Hemric said. “We had made some progress and started getting some track position when the No. 13 spun and got into us. There was quite a bit of smoke inside the truck from the left rear, so felt like we ultimately made the right decision to pit. We started off a little free tonight, and Kevin [Bellicourt] and the guys kept working on it. Just glad we made a little something out of it with our Arnott Chevrolet by the end of the night and gain a few points.”
Start / Finish: 23 / 12
Points Standing / Total: 16th / 116 pts. (-92)
Next Race: Friday, May 1, Texas Motor Speedway
How to Watch or Listen: 8:00 p.m. ET on FS1 or SiriusXM
NAPA:
Daniel Hemric: link hidden, please login to view
Bill McAnally Racing / McAnally-Hilgemann Racing: link hidden, please login to view The post
By NAPA
Christian Eckes vaulted himself back into championship contention with a stout effort at Bristol Motor Speedway on Friday night. The driver of the No. 91 Columbia Bank Chevrolet Silverado RST finished fifth, earned a stage victory and scored the most points of all drivers with 48. Eckes paced the field for 132 of the 250 circuits which helped him advance to fifth in the championship standings, just 17 markers out of the lead.
The Columbia Bank Chevrolet started second after Eckes delivered his best qualifying effort of the year, narrowly missing out on the pole by 0.02 seconds. On lap three, Eckes swiftly claimed control of the event by hooking the bottom of the speedway and held a comfortable lead for 62 of 65 laps in Stage 1. He efficiently navigated lapped traffic to secure his second stage victory of the season and pocketed 10 championship points on lap 65.
In an effort to preserve critical track position, crew chief Dave Elenz elected to keep Eckes on track during the stage caution, along with most lead-lap competitors. When the race restarted on lap 79, Eckes jumped out to another lead and reported his handling had moderately improved from the first segment. He held the lead until a caution on lap 118 flipped the race’s script. Eckes pitted for four tires, as did the majority of the field, but restarted eighth on lap 128 after multiple trucks stayed out on older tires. He was able to regain two positions to run sixth by the end of Stage 2 on lap 130 and tally five points.
Eckes stayed on track to begin the final segment and restarted third on lap 142. A sequence of three cautions over the next 25 laps featured mad scrambles on restarts amongst the top four as Eckes vied to retake the lead. After briefly claiming the lead on the lap-179 restart, Eckes and the No. 1 truck made contact racing for the lead, sparking a multi-truck incident in Turn 1, which he narrowly escaped. He restarted as the leader on lap 179, but a loose balance would eventually hamper his pace over the final 27 laps. Eckes took the checkered flag in fifth for his third top-five result of the year and his second-highest point total of the season.
“It was a step in the right direction for sure,” Eckes said. “I think we led the most laps, had the fastest lap, so we’re bringing fast trucks. Qualified second. Qualifying has been kind of an issue for us for the last couple weeks. I feel like we’re heading in the right direction on there. Just need to clean up a lot of mistakes on my end. I lost the handling a little bit and track position is so important. I just screwed up the restart pretty bad and screwed up the restart before then. Lot of mental decisions I got to make better and we’ll make them at Texas.”
Start / Finish: 2 / 5
Points Standing / Total: 5th / 191 pts. (-17)
NAPA:
Christian Eckes: link hidden, please login to view
Bill McAnally Racing: link hidden, please login to view The post
By NAPA
Daniel Hemric was in position to score his third consecutive top-10 result and continue climbing in the standings, but an unscheduled pit stop thwarted his effort at Rockingham Speedway. The driver of the No. 19
link hidden, please login to view Chevrolet Silverado RST was credited with a 24th-place finish despite scoring stage points and running inside the top-10 for a significant portion of the event.
Hemric hoped to continue his recent rekindled consistency on Friday after qualifying 15th at “The Rock”. Through the first 45-lap segment of the event, Hemric battled a free handling condition and limited his mobility around the blazing-fast one-mile oval. As Stage 1 ran fully under the green flag, Hemric was scored 16th at the first green-checkered flag of the day on lap 45.
Crew chief Kevin Bellicourt elected to throw an early strategy ploy on the first stop of the race. He gave Hemric two tires and fuel under the stage caution which netted eight positions. The ultra-high speeds on Rockingham’s fresh asphalt put a premium on track position and clean air, which made passing significantly challenging. Despite being at a tire disadvantage, Hemric steadily maintained the eighth position and scored three points at the end of Stage 2 on lap 90.
Hemric took four tires and fuel under the second stage caution and restarted 11th on lap 99 as several competitors elected to take two tires. However, during the green flag run, Hemric began experiencing a vibration which became increasingly severe. On lap 139, he pitted for left side tires to address the issue but was forced back to pit road a second time for right side tires. The unfortunate culprit, a loose wheel, sent Hemric to 31st, two laps down. Over the final 50 laps, he was able to salvage a portion of those positions and took the checkered flag in 25th. Following a penalty to the No. 38 truck in post-race inspection, Hemric was credited with a 24th-place result.
“Certainly not how we wanted our day to go,” Hemric remarked. “We were looking at a top-10 day with our NAPA Chevrolet. Kevin [Bellicourt] made a great call early to get us some track position. That was huge to gain those spots because it was so hard to pass. You likely weren’t going to gain that difference on the racetrack. We had speed to maintain our position, even with a tire disadvantage. Thought we could leapfrog a couple guys on the green flag stop, but we never made it that far. Unfortunate for sure, but we’ll put it behind us and move forward as a group to Bristol next week.”
Start / Finish: 15 / 24
Points Standing / Total: 18th / 91 pts. (-99)
Next Race: Friday, April 10, Bristol Motor Speedway
How to Watch or Listen: 7:30 p.m. ET on FS1 or SiriusXM
NAPA:
By elizabeth
Looking for a reliable Cadillac Engine for Sale? You've come to the right place! Whether you drive a Cadillac Escalade, CTS, ATS, SRX, or any other model in the lineup, we have the perfect engine match waiting for you. Nothing matters more than finding the right engine — one that delivers the smooth, powerful performance this legendary brand is known for.
Every engine in our inventory is thoroughly inspected, tested, and verified to meet strict quality standards. We carry a wide selection of OEM-grade and remanufactured engines designed for direct fitment, so installation is seamless and stress-free. With low mileage options available, you can trust you're getting reliable power that will last for miles to come.
Ordering is simple, shipping is fast, and our knowledgeable support team is ready to help you find the exact engine your Cadillac needs. No long waits, no guesswork — just the right part at the right price, delivered straight to your door.
Don't let a failed engine keep your Cadillac off the road any longer than it has to.
🔧 Shop Turbo Auto Parts today — your trusted source for premium engines, fast shipping, and guaranteed satisfaction!
link hidden, please login to view visit site for more details
