Fuel injectors play a huge role in how well an engine runs and how long it lasts. They control how much fuel enters the engine, helping it run efficiently while maintaining power. By understanding the importance of high-quality fuel injectors, counter pros can guide customers toward quality choices that reduce comebacks, restore performance and protect engine components.
Fuel Injector Spray Pattern and Flow
The fuel injector’s spray pattern and fuel flow are critical for fuel economy, emissions and performance. Poorly manufactured injectors can create narrow spray patterns that cause poor atomization, reduced power and lower efficiency. Spray patterns that are too wide can leave unburned fuel dripping down the cylinder wall. That fuel can wash away oil and damage both the wall and piston rings.
Standard’s Testing and Engineering Excellence
Standard’s fuel injectors deliver OE performance through meticulous engineering. At its IATF 16949-certified plant in Greenville, South Carolina, each injector undergoes extensive testing. Engineers test injectors for spray pattern, fuel flow, thermal cycling, endurance and vibration. Standard verifies the performance of its
under real-world conditions at its testing center in Texas.
Complete Line of Fuel Injection Components
High-quality GDI and MFI fuel injectors are part of a larger program that includes fuel pressure sensors, pumps, O-ring kits, regulators and more. With more than 1,900 part numbers, Standard offers a comprehensive line of fuel injection components designed for OE-matching performance.
Causes of Fuel Injector Failure
Fuel injectors can fail due to electrical issues or contamination from dirty fuel. GDI injectors commonly experience carbon buildup. If these problems lead customers to replace fuel injectors, it’s best to replace them all at once. Installing one new injector alongside several older ones might turn off the check engine light, but it won’t fully restore performance or fuel economy. Another injector could soon fail.
Long-Term Benefits of Reliable Injectors
While cheaper or remanufactured injectors may seem appealing, recommending precision-engineered, reliable fuel injectors pays off. They reduce warranty claims, increase customer satisfaction and maintain customer trust.
This video is sponsored by
      Fixing a fuel tank? Check Dorman first.
      On the surface, the primary role of a parts professional is to help our customers identify and select the parts, supplies and services needed to complete a multitude of repairs. However, there are many other duties beyond simple cataloging exercises which separate a true parts professional from a key-punching cashier at the grocery checkout lane. Too often, the general public sees us as simple clerks, but when is the last time you asked a cashier at the register how to perfectly sear that ribeye you just paid for?
      Our customer base may vary from store to store, but many of us deal with an eclectic mix of clientele each day. These patrons also come with varying levels of technical knowledge or abilities. For most of our commercial customers, we are already a trusted partner. Technicians have usually diagnosed and estimated the labor for a repair job before requesting our expertise, but still lean on their “go-to” parts specialist to get the correct components quoted correctly and delivered to them quickly. These customers “speak our language,” and we are expected to speak theirs, as well.
      When it comes to the “decidedly DIY” segment of our business, many of the conversations we have can feel like more of a struggle. Often through no fault of their own, this portion of our population finds themselves tackling unfamiliar repair situations, or attempting to navigate diagnostic recommendations or repair instructions that seem to be written in a completely different language. Our daily interactions with repair professionals and coworkers, as well as our own life experiences, have helped us all to build a knowledge base which serves as one of the main reasons our individual services are in demand to begin with.
      The average consumer views most auto parts as a commodity, so many of our widgets are “all the same” to them. As “car people,” we already know the differences between our products, which ones to recommend, and what we can reasonably expect from them. Even if we don’t physically install components or repair vehicles, we often have a pretty good sense of what it takes to perform the task required, and what else may need to be removed and replaced along the way to the goal of installing the parts we’re handing across the counter.
      When dealing with a “less-technical” parts buyer, we must be prepared to spend a little more time at the counter or on the telephone. Drawing out all of the relevant information (and filtering out the irrelevant) is often the first step in determining the customer’s needs and intentions. If they already have a sense of direction, a portion of the conversation might be spent explaining (in layman’s terms) why triggering a particular OBD-II code does not automatically mean that they should buy part “X,” or deciphering what a customer means when they request “that round box with four wires, next to the square plastic piece under the left fender.”
      Within the context of a popular subreddit (r/explainlikeimfive), we can convey fairly complex technical ideas without anyone feeling lost or talked down to. By avoiding jargon or acronyms, our language becomes more accessible for the uninitiated. Comparisons to everyday situations allow for us to find common ground in a discussion. The use of photos, diagrams, descriptive words and even sounds can make “the big picture” come into focus more sharply for nearly anyone. Once we discover a common language, our common purpose is suddenly much clearer!
