OSC Heat Transfer Products, a US Motor Works brand, released
The OSC Heat Transfer Product release, radiator P/N 2975, is a direct fit for:
-Jeep Wrangler, 2007-2017
-Jeep Wrangler JK, 2018
Built to perform in demanding environments, the heat transfer products help prevent overheating and keep an engine running at its best,
said.
      link hidden, please login to view announced it released eight new AmeriPLATINUM Brake Pad numbers and four new AmeriPRO Brake Pad numbers with a wide range of coverage ranging from Buick Encore to Ford Transit applications. The new SKUs cover over 6mm VIO. Also just released in the
      link hidden, please login to view product line: 1 new AmeriPRO Brake Shoe, 2 new AmeriPRO Wear Sensors, 74 new AmeriPRO Coated and Coated R90 Euro Rotor numbers, and 20 VGX Brake Pad numbers with VIO coverage over 44+mm VIO.
      Transtar announces the release of new premium
      link hidden, please login to view, Part #: T72500C, with the following applications: 2007-2018 Chrysler/Dodge/Ram, 68RFE Transmission  The T72500C is a high-quality transmission solution designed for professional rebuilders and installers who demand consistent performance, precise fitment, and long-term durability, according to Transtar.
      The T72500C goes beyond basic replacement parts,
      link hidden, please login to view said, with improved materials and tighter tolerances- delivering: Longer service life Greater resistance to wear and heat Consistent, dependable performance in demanding conditions The post
