Hey fellow Bobcat owners and equipment pros!
Recently, while checking my Bobcat loader, I noticed the rear idler was wearing more than I expected. If I’d waited longer, it could’ve cost me a lot in repairs. I wanted to share how I spotted the problem early so you guys can save time and money too.
Safety First
Make sure your machine is parked on level ground, engage the parking brake, and lower the bucket. Always turn off the machine completely before touching anything—safety first!
Visual Check
  • Look for cracks, dents, or rust on the rear idler.
  • Check the wear pattern on the idler wheel. Uneven wear, cupping, or flat spots are warning signs.
  • Inspect the seals for oil or grease leaks. Leaks often mean the bearings or seals are failing.
Hands-On Test
  • Try spinning the idler by hand (with the machine OFF!). It should turn freely and smoothly. Grinding or catching = bad bearings.
  • Grab the idler and wiggle it side-to-side. A tiny bit of play is normal, but excessive wobble = serious wear.
Other Things to Watch
  • Track tension is key—too tight or too loose will wear the idler faster.
  • Compare both rear idlers. Uneven wear might indicate misaligned tracks, frame issues, or problems with nearby rollers or sprockets.
  • Run the loader slowly in a safe area and listen for grinding, squealing, or clunking sounds from the rear track area.
Quick Check on Other Parts
Sometimes the idler isn’t the real culprit—it could be the tracks, sprockets, or rollers. Inspect them too so you don’t misdiagnose the problem.
My Conclusion
If you notice wear, wobble, or leaks, replace the rear idler immediately. Ignoring it can lead to track derailment, undercarriage damage, and costly downtime.
By the way, if you’re looking for a high-quality Bobcat loader rear idler, we have them in stock—durable and ready to ship. Use discount code BUYMACHINERYPARTSCODE for a little savings!
🌐 Check out our Bobcat parts:
📧 Email:
📱 WhatsApp: +852 3853 3880
Pro Tip: While replacing the idler, also check track tension and inspect other undercarriage components like rollers and sprockets. A little preventive maintenance goes a long way!
    • By NAPA
      Daison Pursley and the
      link hidden, please login to view No. 9 team officially kicked off the 2026 High Limit Racing season over the past two weeks, competing in six races across Las Vegas Motor Speedway and Central Arizona Raceway. Following an offseason focused on building chemistry and speed, the Kasey Kahne Racing team entered the year with momentum and immediately showed promise against a strong field of competitors.
      The High Limit season opener at Las Vegas Motor Speedway marked the first points-paying events of the year, and the NAPA No. 9 ran consistently inside the top 10 throughout the three-night weekend.
      On Thursday, Pursley qualified eighth in Flight A and advanced to a 12th-place finish in the feature after starting 15th. Friday brought one of the team’s strongest performances of the weekend, as Pursley qualified third, ran up front in the heat race, and drove from ninth to sixth in the A-Main.
      The weekend concluded Saturday with another solid showing as the NAPA No. 9 qualified third once again and advanced from 13th to 10th in the feature. The consistent results to open the season positioned the team well in the early championship standings and reinforced the speed shown throughout the offseason.
      The team carried that momentum into Central Arizona Raceway for the Cactus Classic, where Pursley delivered a standout performance on Thursday night. After qualifying 10th in a stout, 31-car field, Pursley advanced through his heat race and charged from 10th to a third-place finish in the A-Main, earning the first ever podium for the NAPA No. 9 team.
      Friday and Saturday presented challenges, as the team continued to show speed but was ultimately sidelined by incidents in both feature events, resulting in a pair of DNFs. Despite the setbacks, the pace of the NAPA No. 9 remained evident throughout the weekend.
      The NAPA No. 9 team now turns its focus to the next event at Vado Speedway Park in New Mexico on Tuesday as the 2026 High Limit Racing season continues.
      Start / Finish:
      Thursday, March 12, Las Vegas Motor Speedway: 15 / 12
      Friday, March 13, Las Vegas Motor Speedway: 9 / 6
      Saturday, March 14, Las Vegas Motor Speedway: 13 / 10
      Thursday, March 19, Central Arizona Raceway: 10 / 3
      Friday, March 20, Central Arizona Raceway: DNF
      Saturday, March 21, Central Arizona Raceway: DNF
      Points Standing / Total: 11th / 281 pts. (-125)
      Next Race: Tuesday, March 24, Vado Speedway Park, Vado, NM
      How to Watch or Listen:
      link hidden, please login to view NAPA:
      link hidden, please login to viewDaison Pursley:  link hidden, please login to view
      Kasey Kahne Racing:  link hidden, please login to view The post
    • By GreenGears Auto Limited
      Published by GreenGears Auto  |  9 minute read  |  Differential Repair & Replacement Guides
      A bad rear differential doesn't always mean replacing the entire unit. Depending on what has failed — a worn pinion seal, a collapsed bearing, a chipped gear, or a completely seized carrier — the right repair approach ranges from a simple seal replacement to a complete used OEM assembly swap. Knowing exactly which parts are causing the failure determines how much the repair costs and how long the fix lasts. At GreenGears Auto, we source OEM used rear differentials and individual differential components across every major make and platform. This guide covers every replacement part involved in a rear differential repair — what it does, when it needs replacing, and how to source correctly.
      Understanding What Failed — and Why It Matters
      A "bad rear differential" is not a single diagnosis — it's a category of failures that spans a wide range of severity, cost, and repair approach. Correctly identifying the specific failed component before ordering any parts is the most important step in the entire repair process.
      #1 Fluid neglect — the leading cause of rear differential failure across all makes and platforms   60–70% Of rear differential failures involve bearing or seal damage traceable to low or contaminated fluid   50–70% Savings using OEM used assembly vs. new OEM differential on most platforms   🔧 Diagnose Before You Order The most expensive rear differential repair mistake is ordering a complete used assembly when only a seal, bearing, or pinion is actually failed — or conversely, ordering individual rebuild parts when the ring and pinion gear set is chipped or scored beyond serviceability. A proper diagnosis before ordering saves both time and money. GreenGears Auto's parts specialists can help confirm what your specific failure requires.
      Know the Symptoms — Match the Failed Part
      Each rear differential failure mode produces a distinct symptom pattern. Matching symptoms to components before ordering is the fastest path to a correct repair.
      🔊 Whining or Howling Noise
      Steady whine that changes pitch with speed → Ring and pinion gear wear or incorrect backlash Whine under acceleration that disappears on deceleration → Pinion bearing wear Noise only in turns → Spider gears or side gears worn Howl at specific speed ranges → Ring gear damage or incorrect gear mesh
      💥 Clunking or Banging
      Clunk on initial acceleration from rest → Worn U-joints, loose pinion nut, or worn splines Clunk during turns at low speed → Spider gear or carrier bearing wear Loud bang under hard acceleration → Broken ring or pinion tooth Intermittent clunk on deceleration → Pinion preload too low
      💧 Leaks & Fluid Issues
      Leak from rear of differential → Pinion seal failure Leak from axle tube ends → Axle shaft seals worn Leak from cover gasket → Cover gasket failure or loose bolts Dark, metallic fluid on inspection → Internal wear — bearing or gear damage Milky fluid → Water contamination through failed seal or vent
      🔩 Vibration & Handling
      Vibration that increases with speed → Carrier bearing wear or ring gear runout Chatter in turns (AWD/LSD vehicles) → Limited-slip clutch pack worn or incorrect fluid Shudder during cornering → LSD friction material worn Complete loss of drive → Broken ring gear, carrier, or axle shaft
      Rebuild vs. Replace — Making the Right Call
      The decision between rebuilding the existing differential and replacing it with a used OEM assembly depends on four factors: the nature of the failure, the vehicle's value, the availability of quality used assemblies, and the cost of rebuild parts vs. a complete unit.
      🔧 When to Rebuild (Individual Parts)
      Failure is limited to seals, bearings, or the pinion nut — the ring and pinion and carrier are in good condition Ring and pinion gear set is discontinued or unavailable as a used OEM assembly The vehicle is a classic, collector, or specialty vehicle where matching OEM parts are critical The differential housing itself is unique and must be retained A qualified differential specialist is available to perform the rebuild correctly
      ♻️ When to Replace (Used OEM Assembly)
      Ring and pinion, carrier, or bearings are worn or damaged beyond seal-and-bearing repair The failure is advanced and multiple internal components are affected simultaneously A quality used OEM assembly is available from a low-mileage donor — the economics strongly favour replacement Shop labour rates make a full rebuild more expensive than a used assembly swap The vehicle needs to be back in service quickly — assembly swap is faster than a full rebuild   💡 The Used OEM Assembly Advantage For most rear differential failures on common platforms — Ford Explorer, Toyota 4Runner, Chevrolet Tahoe, Honda Accord — a used OEM assembly from a low-mileage donor costs less than a complete rebuild kit and takes half the labour time to install. The maths strongly favour the used assembly on any vehicle where a quality used unit is available.
      Best Replacement Parts for a Bad Rear Differential
      Here is every component involved in a rear differential repair — ranked by how frequently it drives the decision between a targeted repair and a complete assembly replacement.
      🏆 Best Overall Solution Complete Assembly
      Used OEM Rear Differential Assembly
      Typical Price Range: $180–$900 depending on platform A complete used OEM rear differential assembly — pulled from a low-mileage donor vehicle and inspected before listing — is the single best replacement option for the majority of rear differential failures. It eliminates the uncertainty of a rebuild by providing a factory-assembled unit with known internal geometry, correct backlash, and properly preloaded bearings. Installation labour is significantly lower than a rebuild, and the used assembly cost is typically comparable to or lower than the cost of individual rebuild parts.
      Why a complete assembly is usually the right choice:
      Factory-correct ring and pinion backlash and bearing preload — no specialist setup required at installation All internal components are in the same service-life condition — no mismatched wear between new bearings and worn gears Installation is a bolt-in operation — axle shafts, driveshaft, and brake hardware transfer directly from the old unit Total cost (parts + labour) is almost always lower than a full rebuild on common platforms GreenGears Auto inspects fluid condition, housing integrity, and bearing noise on every assembly before listing
      Best platforms for used OEM assembly sourcing:
      Ford Explorer / F-150 (8.8-inch): $220–$480 — outstanding availability, 8.8-inch ring gear, widely regarded as one of the best OEM rear differential designs in the market Toyota 4Runner / Tacoma / Tundra: $280–$620 — Toyota's conservative over-engineering produces used assemblies with exceptional remaining service life Chevrolet Tahoe / Silverado (8.6-inch / 14-bolt): $280–$680 — high-volume platform with excellent used availability; 14-bolt units are particularly sought-after for their load capacity Honda Accord / CR-V AWD: $180–$380 — highest availability and most affordable used differential assembly in the market Jeep Grand Cherokee / Wrangler (Dana 44 / Dana 35): $220–$520 — Dana 44 is the preferred unit; widely available and well-documented Subaru Outback / Forester AWD: $200–$440 — Subaru's rear differential units are compact, reliable, and well-priced in the used market
      🔧 Most Common Standalone Repair Individual Part
      Pinion Seal (Rear Input Seal)
      Typical Part Cost: $15–$45 The pinion seal is the rubber lip seal that prevents differential fluid from leaking around the pinion shaft where the driveshaft connects to the differential. It is the single most commonly replaced individual rear differential component — and the repair that most frequently prevents a minor leak from becoming a catastrophic internal failure. A pinion seal leak is almost always repairable without disturbing the internal differential components, provided it is caught before fluid level drops significantly.
      Always use OEM or OEM-equivalent pinion seal — seal lip geometry is matched to the pinion shaft diameter and surface finish of your specific differential Inspect the pinion flange surface for scoring or wear grooves before installing a new seal — a damaged flange will destroy a new seal within a few thousand miles Measure pinion nut torque before removal and restore to the same preload at reinstallation — incorrect pinion preload after seal replacement is a common cause of premature bearing failure Replace the pinion seal whenever performing any other rear differential work — it is inexpensive and inaccessible without removing the driveshaft anyway
      🔧 Second Most Common Repair Individual Part
      Axle Shaft Seals (Inner Axle Seals)
      Typical Part Cost: $12–$35 per side Axle shaft seals prevent differential fluid from migrating outward along the axle tube to the wheel bearing and brake assembly. A failed axle shaft seal is the leading cause of contaminated rear wheel bearings and oil-soaked brake pads — making it a safety-relevant repair, not just a maintenance item. On rear-wheel-drive and 4WD vehicles, axle shaft seal failure is often misdiagnosed as a brake or wheel bearing problem until the source is traced back to the differential.
      Always replace axle shaft seals in pairs — if one has failed, the other is at similar mileage and condition Inspect the axle shaft bearing surface for wear grooves at the seal contact point before installing new seals Check brake pads and rotors for oil contamination after an axle seal failure — contaminated brake friction material must be replaced, not cleaned OEM seals are strongly preferred over generic equivalents — lip geometry and material compound are matched to the specific axle shaft surface finish Always replace axle shaft seals when installing a used OEM differential assembly — they are inexpensive and the most common post-install leak point
      ⚙️ Primary Noise Source Individual Part
      Pinion Bearing (Front & Rear Pinion Bearings)
      Typical Part Cost: $40–$120 per bearing Pinion bearings support the pinion shaft — the input shaft that meshes the ring gear with the driveshaft — at two points: a larger front bearing near the pinion flange and a smaller rear bearing deeper in the housing. Pinion bearing wear produces the most diagnostically distinctive sound of any rear differential failure: a whine that is loudest under acceleration and significantly reduced or absent on the overrun (deceleration with foot off the throttle). This load-dependent noise pattern is the primary indicator that distinguishes pinion bearing failure from ring-and-pinion gear wear.
      Pinion bearings must always be replaced as a matched set — front and rear together — never replace just one bearing Pinion bearing replacement requires correct preload setup at reassembly — this is a specialist operation requiring a torque wrench and bearing crush sleeve or solid spacer Always source OEM or OEM-equivalent bearing sets — generic bearings frequently have slightly different internal geometry that causes premature failure when set to OEM preload specifications If pinion bearing wear is confirmed, inspect the ring and pinion gear set for surface pitting before committing to an individual bearing repair — a complete used assembly may be more cost-effective if the gears show wear 🔧 When Pinion Bearing Replacement Triggers a Full Assembly Decision If pinion bearing wear is caught early (whine just beginning, no metallic debris in fluid), a bearing-only repair is viable. If the fluid shows significant metallic debris or the gears show surface pitting visible on inspection, the economics shift decisively toward a used OEM assembly — the bearing damage has likely spread to the ring and pinion gear surfaces.
      ⚙️ Structural Load Bearings Individual Part
      Carrier Bearings (Side Bearings)
      Typical Part Cost: $35–$95 per bearing Carrier bearings — also called side bearings — support the differential carrier (the housing that contains the spider gears and side gears) within the differential case. They carry the combined lateral load of the ring gear in mesh with the pinion and maintain the correct ring gear-to-pinion gear geometry. Carrier bearing failure produces a rumbling vibration that is load-sensitive and increases with vehicle speed — often confused with a wheel bearing failure until the source is isolated.
      Carrier bearings must be replaced as a matched pair — left and right together; mismatched wear between two carrier bearings causes ring gear runout and noise even with new bearings installed Carrier bearing replacement requires the ring gear backlash to be reset after installation — this is a precision operation that requires dial indicator measurement and shim adjustment The shims that set carrier bearing preload and ring gear backlash are specific to each differential — always document shim thickness before disassembly and measure backlash after reassembly Carrier bearing failure with significant metallic debris in the fluid almost always indicates that ring and pinion gear surface wear is also present — inspect gear teeth carefully before committing to a bearing-only repair
      🔩 Core Gear Set — Most Costly Individual Part Individual Part
      Ring and Pinion Gear Set
      Typical Part Cost: $180–$650 The ring and pinion gear set is the heart of the rear differential — two hypoid gears that mesh at a precisely calculated angle to transfer engine torque from the driveshaft (via the pinion) to the axle shafts (via the ring gear) while providing the final drive ratio reduction. Ring and pinion damage is typically the result of advanced bearing wear (which allows the gears to run out of correct mesh), fluid starvation (which destroys the hypoid gear oil film), or a single high-load impact event (such as a driveshaft U-joint failure that shock-loads the pinion).
      Ring and pinion gear sets must be replaced as a matched set — never replace one without the other; they are lapped together as a matched pair during manufacturing The new ring and pinion must match the original gear ratio exactly — installing a different ratio requires recalibrating the speedometer, ABS, and traction control systems Ring and pinion installation requires precise backlash and bearing preload setup — this is the most technically demanding differential repair and should only be performed by an experienced differential specialist When ring and pinion replacement is indicated, compare the total cost (gear set + bearings + seals + specialist labour) against a complete used OEM assembly — the assembly route is frequently less expensive and produces a more reliable outcome ⚠️ Ring and Pinion vs. Used Assembly — The Cost Comparison A quality ring and pinion gear set for a Ford 8.8-inch differential costs $200–$450 in parts alone. Add carrier bearings ($80–$180), pinion bearings ($80–$180), seals ($30–$60), shims ($20–$40), and specialist setup labour ($200–$400), and the total rebuild cost reaches $600–$1,300. A used OEM 8.8-inch assembly from GreenGears Auto costs $220–$480 including free shipping — and is already correctly set up. The economics of the used assembly are compelling for most repair scenarios.
      🔄 Open Differential Internals Individual Part
      Spider Gears, Side Gears & Thrust Washers
      Typical Part Cost: $60–$180 (kit) Spider gears (also called pinion gears) and side gears are the bevel gears inside the differential carrier that allow the left and right wheels to rotate at different speeds during cornering. They are bathed in differential fluid during operation and are normally very long-lived — but they can be damaged by severe traction events (wheel spin on one side with the other fully loaded), fluid contamination, or the secondary effects of bearing failure that allows the carrier to run out of position.
      Spider gear and side gear wear typically presents as a clunking or grinding noise during turns rather than at highway speed — this distinguishes it from pinion or carrier bearing failure Always replace thrust washers when replacing spider or side gears — worn thrust washers allow gear movement that accelerates wear on new gears installed alongside them On limited-slip differentials (LSD), worn clutch plates are more commonly responsible for turn-related noise than worn spider gears — confirm which component is the actual failure source before ordering Spider gear and side gear replacement on an otherwise serviceable differential is a valid targeted repair — but requires full differential disassembly and backlash re-setup
      ⚡ LSD-Specific Repair Individual Part — LSD Only
      Limited-Slip Differential (LSD) Clutch Pack
      Typical Part Cost: $80–$280 (kit) On vehicles equipped with a factory limited-slip differential — including most Torsen LSD units (Toyota, Audi), clutch-pack LSDs (Ford, GM, Dodge), and electronically controlled LSDs — the friction material in the clutch pack wears over time and produces a characteristic chattering or shuddering during tight low-speed turns. This symptom is often misdiagnosed as a differential bearing failure or incorrectly attributed to the wrong fluid specification.
      LSD chatter during turns is almost always a clutch pack or friction modifier issue, not a gear or bearing failure — diagnose carefully before ordering internal components Always try a fluid drain-and-fill with the correct LSD-specified fluid and friction modifier additive before ordering clutch packs — this resolves the chatter in approximately 30% of cases Clutch pack replacement is a precision operation requiring correct preload setup — incorrect preload produces either continued chatter (too loose) or binding during turns (too tight) On Torsen LSD units (Toyota, Audi), there is no traditional clutch pack — a Torsen unit cannot be rebuilt in the conventional sense; a worn Torsen differential requires a used OEM assembly replacement Always use LSD-specific friction modifier in the refill fluid after clutch pack replacement — standard gear oil without the modifier will cause immediate recurrence of chatter
      💧 Easiest DIY Repair Individual Part
      Differential Cover Gasket & Cover
      Typical Part Cost: $8–$35 (gasket) / $40–$120 (cover) The differential cover seals the rear of the differential housing and provides access to the internal components for fluid changes and inspection. Cover gasket leaks are common on high-mileage vehicles and are among the most straightforward differential-related repairs available — accessible to a competent DIY mechanic and requiring no specialist equipment beyond basic hand tools.
      Always use a new OEM or quality aftermarket gasket when reinstalling the cover — reusing the old gasket is the most common cause of repeat leaks after a cover removal Clean both the cover and housing mating surfaces thoroughly before gasket installation — any old gasket material or RTV residue on either surface will cause a new leak Torque cover bolts in a star pattern to the manufacturer's specification — overtightening crushes the gasket and undertightening allows leaks; both are common DIY mistakes If the cover itself is cracked, corroded, or has been overtightened and warped, replace the complete cover — a warped cover will leak regardless of how new or thick the gasket is Use the cover removal as an opportunity to inspect internal fluid condition — what you find in the fluid tells you whether additional parts are needed
      🔗 Structural Drivetrain Individual Part
      Rear Axle Shafts
      Typical Part Cost: $80–$280 per shaft Rear axle shafts are the steel shafts that run from the differential side gears to the rear wheel hubs. They can be broken by severe high-torque events (extreme off-road use, aggressive launches, or a seized wheel bearing that loads the shaft to failure) or fatigued over time by accumulated stress cycles. A broken rear axle shaft produces an immediate complete loss of drive on the affected side — the vehicle will not move if the shaft is broken on both sides or if the differential itself is seized.
      Axle shaft replacement requires matching the exact shaft length, spline count, and flange bolt pattern — even minor variations prevent correct installation OEM used axle shafts from the same platform are the most reliable sourcing option — aftermarket shafts frequently have different metallurgy that fails at lower stress levels than OEM Always inspect the axle shaft bearing surface at the inner seal contact point and the spline engagement at the differential side gear — wear at either location indicates the shaft is approaching end of life Replace the axle shaft seal whenever replacing an axle shaft — the seal is inaccessible with the shaft installed
      Rear Differential Parts — Repair Decision Reference
      Component Symptom Typical Part Cost Rebuild or Replace Assembly? Pinion Seal Fluid leak at driveshaft connection $15–$45 Individual repair — straightforward Axle Shaft Seals Fluid at wheel / contaminated brakes $12–$35 each Individual repair — replace in pairs Cover Gasket Fluid leak at differential cover $8–$35 Individual repair — DIY-friendly Pinion Bearings Whine under acceleration $40–$120 each Rebuild if gears intact; assembly if gears worn Carrier Bearings Rumble / vibration, speed-sensitive $35–$95 each Rebuild if gears intact; assembly if gears worn LSD Clutch Pack Chatter in turns (LSD vehicles only) $80–$280 Rebuild — try fluid first Spider / Side Gears Clunk in turns, low-speed grind $60–$180 Rebuild if housing intact Ring & Pinion Gear Set Howl / whine, metallic debris in fluid $180–$650 Compare vs. used assembly — usually assembly wins Axle Shafts Complete loss of drive one side $80–$280 each Individual part — OEM used sourcing preferred Complete Assembly Multiple failures / advanced internal wear $180–$900 Replace — best economics for advanced failure
      What to Inspect When Sourcing a Used OEM Assembly
      Drain and Inspect the Fluid
      This is the most informative pre-purchase check available on any used differential assembly. Clean, amber-coloured fluid with no metallic particles confirms healthy internal components. Dark, burnt, or metal-laden fluid indicates internal wear that may not be visible externally. Milky fluid means water contamination — always a disqualifier regardless of price. Rotate the Input Flange and Listen
      With the axle shafts removed or the cover off, rotate the pinion flange by hand through several full revolutions. Smooth, even resistance throughout the full rotation indicates healthy bearings and correct gear mesh. Any roughness, notchiness, or variation in resistance indicates bearing or gear surface wear — reject the unit regardless of external appearance. Inspect Ring and Pinion Gear Teeth
      If the cover is accessible or removable, visually inspect the ring gear teeth for pitting, spalling, chipping, or scoring across the gear face. Each tooth should show an even, smooth contact pattern with no broken or cracked teeth. Even a single chipped tooth disqualifies the assembly — a damaged tooth will rapidly destroy adjacent teeth and the pinion under load. Check Housing for Cracks and Impact Damage
      Inspect the complete differential housing — the centre section, axle tube connections, and all mounting flanges — for cracks, impact gouges, and stripped mounting points. A cracked housing cannot be reliably sealed and will fail under operating load. Pay particular attention to the area around the pinion bore, which is the most structurally stressed location. Verify Gear Ratio and LSD Specification
      Confirm the differential's gear ratio matches your vehicle's original ratio exactly — a ratio mismatch causes drivetrain binding, ABS and traction control errors, and accelerated wear. On AWD and 4WD vehicles, a ratio mismatch between front and rear differentials is especially damaging. Also confirm whether the unit is open or limited-slip — replacing a factory LSD with an open unit eliminates traction capability your vehicle was designed with.
      Always Replace These Parts at Installation
      Whether installing a used OEM assembly or completing an individual component repair, these are the non-negotiable replacement items at every rear differential service — regardless of their apparent condition.
      Pinion seal — always new; the old seal is inaccessible once the driveshaft is reconnected and will degrade faster after being disturbed Axle shaft seals — replace both sides; they are at the same mileage as each other and the cost difference between replacing one vs. both is negligible relative to the labour Differential cover gasket — never reuse; always replace with a new OEM or quality gasket Differential fluid — always drain and fill with the manufacturer-specified fluid; on LSD-equipped vehicles, use the correct LSD fluid with the appropriate friction modifier Pinion flange nut — use a new self-locking nut; reusing the old nut risks it backing off under vibration and losing pinion preload Driveshaft U-joint — inspect at time of differential removal; if showing any play or roughness, replace while the driveshaft is already disconnected
      ✅ GreenGears Auto's Rear Differential Promise Every rear differential assembly in our inventory is inspected for fluid condition, housing integrity, ring and pinion tooth condition, and bearing smoothness before listing. Donor mileage is documented and verified on every unit. Each assembly is backed by our 15 to 90-day satisfaction guarantee with free shipping across the continental US and no core charge required.
      Need Replacement Parts for Your Rear Differential?
      Whether you need a complete used OEM assembly or individual components — tell us your year, make, model, and gear ratio. Our differential parts specialists will find the right solution and get it to you in 3–7 days with free shipping.
      ✅ Fluid Inspected 🚚 Free US Shipping ↩️ 15-Day Returns 📋 Mileage Verified link hidden, please login to view
    • By NAPA
      Christian Eckes returned to EchoPark Speedway in Hampton, Ga., as one of the favorites for the second round of the NASCAR CRAFTSMAN Trucks (NCTS) season. However, the driver of the No. 91
      link hidden, please login to view Nightvision Chevrolet Silverado RST was credited with a 36th-place finish after suffering a broken driveshaft on the second lap.
      Eckes clocked in 15th-quickest in Friday afternoon’s qualifying session, tucked in behind MHR teammate and NAPA brethren Daniel Hemric. After the duo worked the bottom lane on the opening lap, Eckes pulled to the apron on lap two with a broken drive shaft and also lost third and fourth gears. Despite the early exit, Eckes is 10th in the NCTS standings entering next week’s inaugural event on the St. Petersburg, Fla., street circuit.
      “Unfortunate to say the least. This obviously cost us a lot of points and we need to focus on responding at St. Pete next week and put NAPA Nightvision, NAPA Auto Care, Gates Hydraulics up front again and get back at it. Hopefully we can move on from this and be better in the next few weeks.”
      Start / Finish: 15 / 36
      Points Standing / Total: 10th / 47 pts. (-56)
      Next Race: Saturday, February 28th, Grand Prix of St. Petersburg
      How to Watch or Listen: 12:00 p.m. ET on FOX or SiriusXM
      NAPA:
      Christian Eckes:  link hidden, please login to view
      Bill McAnally Racing:  link hidden, please login to view The post
      Garage Gurus | Alternator Diagnostics: Belt & Idler Pulley Inspection
      How To Change Rear Shocks on a 2011-2015 Chevy Cruze
