      For more information, visit
      Would you rather practice swapping a flat tire for a spare or learn the hard way?
      Series Supplier
      Milwaukee Tool announced two new Anti-Vibration Gloves to join its existing lineup of safety gear. Designed for carpenters, remodelers, masons, maintenance and mechanical professionals, these gloves can be worn for professional applications while protecting from harmful tool vibrations. The Anti-Vibration High-Dexterity Nitrile Dipped Gloves provide vibration protection while maintaining high dexterity, according to the company.
      “Hand-Arm Vibration Syndrome (HAVS) is a permanent medical condition that causes loss of feeling in the fingers, hands and arms. With 2 million workers exposed to harmful vibrations daily, we set out to address the risks of prolonged exposure to vibrations from tools and machinery by delivering essential proper protection,” said Austin Dorman, senior product manager at
      link hidden, please login to view. “Designed for primary applications such as concrete drilling, sanding, grinding, cutting, chipping, breaking and demolition work, the Anti-Vibration Cut Level 4 High-Dexterity Nitrile Dipped Gloves and Anti-Vibration Work Gloves meet the critical needs of vibration reduction, dexterity, durability and comfort.”  Milwaukee Tool added that the gloves are reinforced in high-wear areas, such as in the fingertips and palms, to withstand everyday use. They include a breathable lining and built-in terry cloth sweat wipe while keeping hands cool and dry throughout the day. The company also said the gloves are equipped with SMARTSWIPE technology, for a touchscreen-compatible fingertip and knuckle.
      Specifications:
      Anti-Vibration Cut Level 4 High-Dexterity Nitrile Dipped Gloves – 48-73-8762 (L) – $22.97
      •Available in sizes S – XXL
      Anti-Vibration Work Gloves – 48-73-8772 (L) – $29.97
