No, cars haven't always had wipers. Early automobiles lacked many safety features, including wipers, leaving drivers to rely on goggles for protection from rain and debris.
The First Windscreen Wipers
The first wiper was patented in 1903 by Mary Anderson. Her manually operated design allowed drivers to clear the windshield using a lever. In 1917, Charlotte Bridgwood improved on this by introducing an automatic system powered by rollers. Despite their innovations, these early wipers were slow to gain popularity.
Widespread Adoption
By the 1920s, as cars became more common, manufacturers started including wipers as standard equipment. Early systems were vacuum-powered, but in the 1960s, electric wipers became the norm, offering more reliable and efficient performance.
Modern Wipers
Todays wipers are advanced, featuring variable speeds, intermittent settings, and rain-sensing technology. These improvements ensure clear visibility and safety in all weather conditions.
Wipers have come a long way from their manual beginnings, evolving into essential safety features that every car relies on today.
Share your thoughts below🚗💨
      Why some vehicles have more than one spin-on filter
      Wiper blades keep your windshield clear, but since they’re made of rubber, they wear out with time and need to be swapped out regularly.  How long they last really depends on how often you use them, where you drive, and whether you take care of them. Watch for these signs that indicate it's time for new wipers:
      Streaking or Noise
      Visible Damage
      Age Considerations
    • By Alex
      1. Know what part of the wiper blade you'll need to change. In general, windshield wiper blades are made with three basic parts: 1. The lower metal arm is the part that extends from the base of the windshield; 2. The wiper blade is the part attached to the metal arm; and 3. The rubber blade is the part that actually wipes the snow, rain or dust off the windshield glass for you.
      2. Look at the shape of the blade. Many modern cars have curved windshields, so the blade needs to curve too, to make good contact as it wipes. There are many brands of wiper blades with various kinds of packaging, some of which you can see through and some of which you can't. Straight wiper blades are suitable for car with a flat windshield, while slightly curved wiper blades may be more suitable for car with streamline windshield.
      3. Measure or look up the length of the blades that are used on your car’s driver seat and passenger seat sides. You can measure the length of each blade yourself, but in general, most places that sell wiper blades provide a manual where you can look up the lengths for your car make and model..
      4. Check for adapter options. Many wiper blade brands include more than one adapter type in their packaging. These are designed to make the blades compatible with various types of metal arm.
      5. Consider cost. Different kinds of wiper blades can range in price dramatically. Do a little comparison shopping to figure out what wipers fit your price range and are still of good quality.
      How to: Replace the Wiper Blades on a 2013 to 2018 Toyota RAV4
      The collapsible tool every “car person” should have | Dorman 711-900
