Akebono expanded its EURO and Severe Duty Ultra-Premium Disc Brake Pad line by 10 new part numbers: EURO: EUR1867, EUR1867A, EUR1867B & EUR1867C; Severe Duty: SDF1317, SDF1490, SDF1540, SDF1693, SDF1840 & SDF2301. The company said that premium stainless steel abutment hardware and electric wear sensors are included in the kits that require it.
added that for European vehicles, including popular models from BMW such as the 230i, M240i xDrive, 530e, X5 xDrive40i, and more, Akebono Ultra-Premium brake pads ensure a smooth, quiet ride with the promise of “Clean Wheels, No Squeals.”
For fleet vehicles, including the Ford Transit series, Mercedes-Benz Sprinter, and Ram ProMaster, Akebono said its ultra-premium brake pads are designed to provide reliable, long-lasting performance, reducing the need for frequent replacements and ensuring fleets stay on the road, operating efficiently.
“These new part numbers represent our dedication to innovation and customer satisfaction,” said Kirby Pruitt, product development manager at Akebono Brake Corporation. “We remain committed to providing superior brake solutions for every driver, whether they’re behind the wheel of a luxury European car or managing a fleet of hard-working vehicles.”
This recent release of EURO and Severe Duty adds coverage for:
BMW: 230i 22, 330e 22-21, 330e xDrive 22-21, 330i 22-19, 330i xDrive 22-19, 430i 22-21, 430i Gran Coupe 22, 430i xDrive 22-21, M240i xDrive 22, M340i 22-20, M340i xDrive 22-20, M440i xDrive22-21, M440i xDrive Gran Coupe 22, i4 23-22, X3 M240i 23-18, X3 sDrive30i 23-19, X3 xDrive30e 21-20, X3 xDrive30i 23-18, X4 M40i 23-19, X4,  X5 sDrive40i 22-20, X5 xDrive40i 22-19, X7 xDrive40i 22-19, 530e 23-18, 530e xDrive 23-18, 530i 23-17, 530i xDrive 23-17, 540d xDrive 18, 540i 23-21, 540i xDrive 23-21, 640i xDrive Gran Turismo 19-18, 740e xDrive 19-17, 740i 22-16, 740i xDrive 22-17;
Ford: Transit-150 22-20, Transit-250 23-20, Transit-350 23-20, Transit-350 HD 23-20;
Mercedes Benz: Metris 21-16, Sprinter 2500 18-10, Sprinter 3500 18-10, Sprinter 3500XD 18;
Ram: ProMaster 1500 23-14, ProMaster 2500 23-14, ProMaster 3500 23-14
      link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
      Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
      link hidden, please login to view said. Applications & Coverage
      2011-Up Ford F250, F350 and F450 with 6r140 transmission.  2016-Up Ford E350 and E450 with 6R140 transmission.  Available Part Numbers
      TS-FM1261 (6.2L; 6.8L Gas Engines)  TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs)  TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
      SAF-Holland has launched BrakeSight, a brake monitoring system for Haldex air disc brakes that provides continuous, real-time visibility into wear at the wheel end. The company said the system targets fleets seeking more predictable brake service intervals and streamlined repair planning.
      SAF-Holland said BrakeSight helps fleets schedule brake service at the optimal moment, extend rotor life, avoid unnecessary repairs and reduce overall maintenance costs.
      How BrakeSight Brake Monitoring Works
      BrakeSight is an optional feature for the Haldex ModulT air disc brake. As the adjustment mechanism rotates to compensate for pad and rotor wear, the system monitors this movement and translates it into a percentage of remaining pad and rotor life at each wheel end.
      The sensor connects to a frame-mounted electronic control unit (ECU), which converts the signal and outputs real-time data via CAN. Designed for both tractor and trailer air disc brakes, BrakeSight is J1939 compliant and compatible with all telematics platforms. SAF-Holland works with telematics providers selected by the fleet and offers open integration without exclusive partnerships.
      Built for Real-World Fleet Conditions
      SAF-Holland said BrakeSight combines durability with ease of use. Features include:
      Continuous measurement of brake pad wear; Ultrasonically welded sensor housing for long-term durability; IP6K9K sealing for harsh road and wash-down environments; Sensor warranty of 3 years or 350,000 miles, matching ABS coverage; Operating temperature range from -40 C to 125 C. Because all ModulT air disc brake calipers include the sensor mounting feature as standard, OEMs and fleets can add BrakeSight at any stage without replacing the caliper. This supports flexibility throughout the vehicle life cycle.
      By providing real-time insight into brake wear, the system helps fleets create more accurate maintenance schedules, reduce unplanned downtime and protect brake components. The company positioned this as a way to lower total cost of ownership and improve uptime.
      Make Dorman your First Stop for brake solutions
