NexaMotion Group (NMG) was recently awarded a 2025 Deal Maker Award, presented by The Association of Corporate Growth (ACG).
The Deal Maker Awards are created and managed by ACG Cleveland and are designed to highlight those companies or individuals who have been successful in their pursuit of corporate growth through acquisition, joint venture, divestiture, restructuring and financing transactions over the last two years.
was awarded the “Corporate Deal Maker” Winner for 2025, which was presented by ACG Cleveland on Jan. 29, 2025, in Cleveland, Ohio.
has been on a significant growth trajectory, acquiring five businesses in the last two years,” said Neil Sethi, CEO of NexaMotion Group. “Each acquisition was carefully chosen to align with our long-term strategic plan and our company’s vision and values. This award is a testament to the hard work and efforts of our team both in the industry and the community, and we’re grateful for the recognition from ACG Cleveland.”
    • By Auto News
      Published by GreenGears Auto  |  8 min read  |  Subframe Buying Guide
      3. Corrosion Protection
      Premature tyre wear
      Our
      🛡️ 90-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns
      link hidden, please login to view proudly presented link hidden, please login to view (GPD) with the 2026 Receiver’s Choice Award at the Auto Care Association’s Automotive Content Professionals Network (ACPN) Knowledge Exchange Conference, held May 11–14 in Atlanta. The award recognizes GPD’s commitment to delivering high-quality, accurate and complete product content, along with its dedication to continuous improvement and industry best practices. The Receiver’s Choice Award honors organizations that provide exceptional content, including ACES, PIES, digital assets, and customer-specific formats. Recipients are selected by content receivers who support ACPN and are evaluated based on accuracy, timeliness, completeness, consistency, and overall data integrity.
      The 2026 award was presented by Lance Brierley, director of technology solutions, and Jimmy Golden, director of eCommerce solutions at Alliance Headquarters.
      “GPD’s commitment to maintaining clean, accurate, and timely content has made a measurable impact across our data ecosystem,” said Jimmy Golden. “Their team consistently demonstrates a strong understanding of the standards and responsiveness required to support our distribution and sales efforts.”
      “What set GPD apart is not only the quality of their data, but also their proactive approach to collaboration and continuous improvement,” added Lance Brierley. “They’ve shown a clear dedication to advancing content excellence in a way that benefits the entire network.”
      Global Parts Distributors was recognized for its outstanding performance in content delivery and for playing a key role in strengthening the digital foundation of product representation across the Alliance network.
      link hidden, please login to view congratulates Global Parts Distributors on this well-deserved recognition and looks forward to continued collaboration and success. Pictured from Left to Right: Lance Brierley, John Johnson, Kassandra Dore, Natalie Houseman and Jimmy Golden.
      Are you looking for a powerful and reliable Chevy Silverado at an affordable price? We offer an outstanding selection of Chevy Silverado trucks built for hard work, adventure, and everyday driving excellence. Each Chevy Silverado in our inventory is carefully inspected for performance, safety, and reliability, ensuring you get a truck that meets your highest expectations. Available in multiple trim levels, cab configurations, and engine options, we have the perfect Silverado to match your lifestyle and budget. Our dedicated team provides expert guidance, easy financing solutions, and exceptional customer support from start to finish. Whether you need a workhorse or a weekend warrior, shop our trusted Chevy Silverado inventory today and find your perfect truck!
      WIX Filters announced that the company was honored with the 2025 Parts Warehouse Inc. (PWI) Marketing Support Award at PWI’s annual Red, White and Revved Up conference. The conference took place in April in Rogers, Arkansas, celebrating store wins, providing technical training to attendees and promoting the various vendors that contribute to PWI’s success.
      Marketing Support and Annual Meetings
      Honored over 40 other contenders,
      link hidden, please login to viewwas recognized for its overall engagement and investment in promoting PWI. WIX Filters opened a direct line for sharing assets to support both organizations’ success in 2025. The company developed marketing campaigns that boosted sales and customer awareness and actively participated in PWI’s annual marketing meetings. “PWI is defined by their commitment to providing unparalleled service alongside high-quality auto parts,” said Carmina Lopez, brand manager at WIX Filters. “WIX Filters has been a prominent partner with PWI for over 35 years, and this award recognizes our commitment to developing and enhancing customer relationships while aligning our sales and marketing efforts with PWI.”
      Light- and Heavy-Duty Filters for PWI Customers
      Equipping PWI with both heavy- and light-duty products,
      link hidden, please login to view supplies its customers with oil, cabin and air filters. These filters support both light-duty passenger vehicles and heavy-duty agricultural and construction machinery.
