MANN+HUMMEL Releases Fuel Filter Disassembly Tool
link hidden, please login to view introduces a new line of Transtar Brand 100% all New Components Torque Converters which it said are engineered specifically for 2011-up Ford Trucks and Vans equipped with 6R140 transmissions. Designed to meet the demands of modern gas and diesel powertrains, these converters deliver consistent, dependable performance for today’s rebuilders and come with a 12-month/unlimited mileage warranty.
Developed by an engineering team with decades of experience supporting global automotive programs, all converters are manufactured to OE specifications and designed to meet or exceed factory performance standards,
link hidden, please login to view said. Applications & Coverage
2011-Up Ford F250, F350 and F450 with 6r140 transmission. 2016-Up Ford E350 and E450 with 6R140 transmission. Available Part Numbers
TS-FM1261 (6.2L; 6.8L Gas Engines) TS-FM1262 (6.7L Diesel Engine, 6 Mounting Studs) TS-FM1265 (7.3L Gas Engine) For optimal performance, pair with Transtar Low Viscosity Fluid.
By Mighty Auto Parts
link hidden, please login to view appeared first on link hidden, please login to view. When filters bulge or split at the seam, gaskets protrude from their base plate and oil is dripping from the engine and chassis, the oil filter often gets the blame. Some install a second or third filter, convinced the filter is the culprit. The fact is the filter encountered overpressurization due to a stuck pressure […]
