I can't find a rebuilt brake booster for my 1978 Dodge D-150 truck anywhere; I have been hunting for months.  The Chrysler number is 4094149.  The A-1 Cardone number is 54-73716.   I would settle for a rebuildable core at this point; my old booster is rusted-out on the back side so it is no good as a core.
hello , hope you are doing .
If you're in search of a brake booster for your 1978 Dodge D-150 truck, look no further! You can find what you need at autopartsforsalenearme.com. We recently ordered a Dodge engine from them and had a positive experience.
At autopartsforsalenearme.com, you can order the brake booster with delivery typically within 10-20 days, depending on your location. They offer a wide range of parts for various Dodge models, including older trucks like the D-150.
Whether you're restoring a classic vehicle or performing routine maintenance, autopartsforsalenearme.com provides reliable service and quality parts. Don't hesitate to check them out for your automotive needs.
    • By juliaanderson
      One thing I've noticed is that many drivers pay attention to engine performance or tyre condition but often forget about their braking system until something feels wrong.
      I've started making it a habit to check the condition of my brake pads during regular maintenance instead of waiting for warning signs. It gives me more confidence on the road and can help avoid unnecessary repair costs later.
      What about everyone else here? Do you replace brake pads on a schedule or only when you notice noise, vibration, or reduced braking performance? I'd be interested to hear what maintenance routine has worked best for you.
      Published by GreenGears Auto  |  6 min read  |  Steering Parts Buying Guide
      Search our
      🛡️ 15-Day Warranty  ·  🚚 Free US Shipping  ·  ↩️ 15-Day Returns  ·  📋 Mileage Verified
      SAF-Holland has launched BrakeSight, a brake monitoring system for Haldex air disc brakes that provides continuous, real-time visibility into wear at the wheel end. The company said the system targets fleets seeking more predictable brake service intervals and streamlined repair planning.
      SAF-Holland said BrakeSight helps fleets schedule brake service at the optimal moment, extend rotor life, avoid unnecessary repairs and reduce overall maintenance costs.
      How BrakeSight Brake Monitoring Works
      BrakeSight is an optional feature for the Haldex ModulT air disc brake. As the adjustment mechanism rotates to compensate for pad and rotor wear, the system monitors this movement and translates it into a percentage of remaining pad and rotor life at each wheel end.
      The sensor connects to a frame-mounted electronic control unit (ECU), which converts the signal and outputs real-time data via CAN. Designed for both tractor and trailer air disc brakes, BrakeSight is J1939 compliant and compatible with all telematics platforms. SAF-Holland works with telematics providers selected by the fleet and offers open integration without exclusive partnerships.
      Built for Real-World Fleet Conditions
      SAF-Holland said BrakeSight combines durability with ease of use. Features include:
      Continuous measurement of brake pad wear; Ultrasonically welded sensor housing for long-term durability; IP6K9K sealing for harsh road and wash-down environments; Sensor warranty of 3 years or 350,000 miles, matching ABS coverage; Operating temperature range from -40 C to 125 C. Because all ModulT air disc brake calipers include the sensor mounting feature as standard, OEMs and fleets can add BrakeSight at any stage without replacing the caliper. This supports flexibility throughout the vehicle life cycle.
      By providing real-time insight into brake wear, the system helps fleets create more accurate maintenance schedules, reduce unplanned downtime and protect brake components. The company positioned this as a way to lower total cost of ownership and improve uptime.
      Make Dorman your First Stop for brake solutions
