The thermostat is a crucial component in your car's engine system, playing a vital role in regulating the engine temperature. Contrary to common beliefs, removing your car's thermostat can lead to severe consequences, affecting fuel efficiency and engine lifespan. In this article, we will explore the benefits of retaining the thermostat and explain why removing it should be avoided.
  • 1 year later...
    • By juliaanderson
    • By juliaanderson
      How to Change Your Oil: 2004-2008 Ford F-150 | O’Reilly Auto Parts
