Car led light,bulb,accessories
Go to solution Solved by Colight,
Colight focuses primarily on the latest automotive lighting asLaser lights, LED headlights, LED light bars, LED work lights, and accessories.We commit to offering a variety of cool-designed, functional and quality products in the Colight online store, which will be affordable to as many people as possible.
  • Solution
COLIGHT is synthesized by "COOL" and "LIGHT", that means to be cool. Found in 2016, Colight focuses primarily on the latest automotive lighting asLaser lights, LED headlights, LED light bars, LED work lights, and accessories.We commit to offering a variety of cool-designed, functional and quality products in the Colight online store, which will be affordable to as many people as possible.
    • By Exhaust Auto
      Hey everyone, I’ve been researching car resonators for a custom exhaust build and wanted to ask for some advice. How do resonators help refine the exhaust sound and reduce unwanted noise frequencies? I’ve heard they can improve the overall exhaust note and performance, but I'm curious if they really make that much of a difference for performance tuning.
      Any suggestions or experiences would be awesome, especially if you've worked with resonators for tuning your vehicle. Thanks!
      If Someone check this product detail visit this :  link hidden, please login to view
      car-Resonator-Muffler.avif
      How car wiper works
      Car wipers help drivers see clearly when it's raining or snowing. They’re a small but important part of the car. Here’s a simple look at how they work:
      Wiper Blades
      They’re just rubber (or sometimes silicone) strips that slide across your windshield to keep it clear.
      Wiper Arms
      The metal arms hold the blades and move them back and forth across the glass.
      Wiper Motor
      There’s a little electric motor under the hood that makes the arms move. It’s usually under the hood.
      Linkage
      This is a set of mechanical parts that connect the motor to the arms. It makes sure both arms move together smoothly.
      Wiper Pivot
      This is the spot where the arms are attached to the car. It lets the arms rotate as they move.
      Wiper Switch
      You turn the wipers on and off with a switch—usually on the dashboard or the steering wheel.
      Wiper Relay
      This part controls the power going to the motor. It helps the wipers run at different speeds, like slow, fast, or on and off (intermittent).
      How It All Works Together
      When you turn on the wipers, the switch sends a signal to the relay. The relay gives power to the motor. The motor starts spinning, and the linkage changes that spinning motion into the back-and-forth movement of the arms. They just sweep across the windshield and get rid of whatever’s in the way.
      Intermittent Wiping
      For light rain, you can use the intermittent setting. It makes the wipers move with short pauses in between.
      Washer System
      Most cars also have a washer system that sprays cleaning fluid on the windshield. When you press the washer button, a small pump sprays the fluid through nozzles to help clean the glass.
