How To: Replace the Thermostat in a 2009 to 2017 Ford F-150
- 70 views
- 128 views
- 213 views
- 282 views
- 222 views
By abenleulmi
The thermostat is a crucial component in your car's engine system, playing a vital role in regulating the engine temperature. Contrary to common beliefs, removing your car's thermostat can lead to severe consequences, affecting fuel efficiency and engine lifespan. In this article, we will explore the benefits of retaining the thermostat and explain why removing it should be avoided. link hidden, please login to view -
By WiperTech008
Streaking or Noise
Visible Damage
Age Considerations
By WiperTech008
By jacob_1994
I broke the steering knuckle on my truck and can not find the part anywhere, i need to know if there is another year that fits or if you know where i can get one or have part numbers. the truck is a 1999 ford ranger xlt 4x4 4L v6
