Stop Doing This! 5 Deadly Sins Killing Your Car's A/C System Every Summer 🛑❄️
By Autoservice Paulus GmbH
With changing seasons, I was wondering if you adjust anything in your car maintenance routine?
For example, things like tire checks, AC usage, battery care, etc.
Do you follow any seasonal habits or just drive as usual?
If you've owned a Ford long enough, you've probably heard someone say, "It turned out to be the PCM." While the Powertrain Control Module (PCM) isn't the most common failure point, it can create symptoms that look like almost anything else.
Because the PCM controls critical engine and transmission functions, a fault can easily be mistaken for bad sensors, ignition issues, or even a failing transmission. That often leads to replacing parts that weren't actually the problem.
Common Symptoms of a Failing Ford PCM
Here are some of the symptoms I've seen discussed most often:
Check Engine Light that returns after repairs Engine cranks but won't start Random stalling while driving Rough idle or engine misfires Poor fuel economy Delayed or harsh transmission shifts Cooling fan running constantly Multiple communication (U-code) errors No communication with the scan tool The tricky part is that these symptoms can also be caused by wiring problems, low battery voltage, damaged grounds, or faulty sensors.
Don't Assume the PCM Is Bad
Before replacing the PCM, it's worth checking a few basics:
Battery voltage and charging system All PCM power and ground circuits Fuses and relays Wiring harness damage Corroded or loose connectors CAN Bus communication Water intrusion around the PCM I've seen situations where a damaged ground cable or corroded connector caused symptoms identical to a failed PCM.
Ford Models That Come Up Frequently
Certain Ford platforms seem to generate more PCM-related discussions than others, including:
Ford F-150 Ford Explorer Ford Escape Ford Expedition Ford Mustang Ford Ranger Ford Super Duty (F-250/F-350) Ford Fusion That doesn't necessarily mean the PCM is defective—it simply means these vehicles are commonly diagnosed when electrical or drivability issues appear.
When Replacement Becomes Necessary
If you've confirmed the PCM itself has failed, replacing it isn't always as simple as plugging in another module. Depending on the model year and vehicle, the replacement PCM may require:
VIN programming Security (PATS) programming Calibration updates Idle or transmission relearn procedures Installing an incorrect or unprogrammed module can prevent the vehicle from starting or lead to additional fault codes.
Modern Ford trucks and SUVs rely heavily on electronics, so accurate diagnosis is more important than ever. Taking the time to verify power, grounds, wiring, and communication before replacing expensive components can save both time and money.
Discussion
For those who own or work on Ford vehicles:
What Ford model gave you the most trouble? Have you ever had a PCM fail, or did the issue turn out to be something else? What symptoms led you to the final diagnosis? I'd be interested to hear everyone's experiences and see if there are any common patterns across different Ford models.
Â
By juliaanderson
By juliaanderson
By oliviarosesmith
Planning a summer road trip in my Jeep and part of the route runs through some pretty remote wildlife areas — think deer, maybe elk depending on elevation. Never had a close call yet but I'd rather be prepared than find out the hard way at 60mph.
Been going back and forth on whether to upgrade the stock bumper before I go. A few things I'm weighing:
Does a heavier aftermarket bumper actually help in an animal strike, or is it more about looks/winch mounting for most people? Front vs rear — is front the priority if I'm mainly worried about wildlife on the road? Anyone dealt with insurance/deer strikes and wish they'd had better protection beforehand? Budget isn't unlimited so trying to figure out if this is a "nice to have" or something I'll actually regret skipping. Would love to hear what setups people are running, especially if you've done a similar trip or actually hit something with stock vs. upgraded bumpers.
Trip's about 3 weeks out so I've got a little time to sort parts and get them installed before I leave.
